Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through August 19, 2004 > Boston Acoustics A120
Author Thread: Boston Acoustics A120
Username: Cubancorona
Charlottesville, VA
The foam around the 10" cone finally broke off. Is there any way I can replace it? I love these speakers and would hate to lose them because of this.
Also, I'm very interested in audio/speaker theory, but I don't know where to get started. Can anyone recommend some good links/tutorials?
Thanks!
Relevant Product Info
j. Vigne
Just put something like speaker surround recone into a search engine and you will find someone to send you the kits to redo the surrounds. you can also check with shops that do pro audio/sound reinforcement for someone in your area to do the repair.
Start with "definitions and descriptions" under this site on the forum.
http://forum.ecoustics.com/bbs/messages/1/56618.html
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through August 19, 2004 > Boston Acoustics A120 [ « Previous ] [ Next » ]
