Thread: Recording tracks using optical out on PC |
renegade Unregistered guest |
| Posted on Friday, July 30, 2004 - 07:30 am: |
I have a digital out on the sound card on my PC. I have tried transferring tracks to my mini-disc recorder using the optic cable, but the audio out on my M-D receives it as a loud whining hum. I'm guessing it has something to do with copy protection by the audio player software on the PC. I have tried using both media player & winaamp with no luck. I have a Sony MZR-900. Any suggestions? |
JayVeeCee Unregistered guest |
| Posted on Wednesday, August 11, 2004 - 01:19 pm: |
Did you really mean to connect the digital "out" from your PC to the digital "out" of your mini disc. Some optical ports are dedicated to either "in" or "out" only. |
| Posted on Wednesday, October 27, 2004 - 12:24 am: |
sir i have an optical deck aplpine\luxman A-007 now the problem is that it cannot play an optical cd player. i have also check the opticl cable the cable is ok. Now tell me the reason and please if you have the web address and web site of aplpine\luxman. tell me thanks |
md master Unregistered guest |
| Posted on Saturday, February 05, 2005 - 06:11 am: |
If you are using pc out to md in, then turn the volume down on your line in, so the audio from the pc source does not feed back from the digital out to the line in. |
Silver Member Username: Ustaad_hc
Post Number: 721 Registered: Oct-06
| Posted on Thursday, April 30, 2009 - 12:34 am: |
