Thread: Which one should I buy |
Anonymous |
| Posted on Friday, July 12, 2002 - 03:55 pm: |
I just bought the HK320 and would like to take advantage of the 6.1/7.1 feature(I know i could of bought a receiver with a built in 6 channel)Any suggestion on what type of amp, or brand I should buy, I don't want to spend to much money, can anybody help... |
Anonymous |
| Posted on Wednesday, November 20, 2002 - 07:04 pm: |
Most any two channel amp or receiver will handle the center rears. For good used amps go to audiogon.com and peruse the offerings. I have a Marsh Sound Design A200S for $800 ($1,495 new) but that is probably more than you want to spend for the rear but it would sound great on your main front speakers. DS |
Anonymous |
| Posted on Thursday, January 02, 2003 - 02:34 pm: |
i would try to stick w/ the same brand as the receiver, I think H/k makes the pa2000 a 2 channel amp. It can be had for 500 or less on the net new, probably much less on audiogon or ebay used. |
Anonymous |
| Posted on Thursday, January 02, 2003 - 03:51 pm: |
Ya, the pa2000 seems to be a good matching amp for the HK avr's. I've got the 520 and I'm in the same position as you...building slowy. |
