Thread: Blueroom Minipod/Cinepod 5.1 Home Theater Speaker System Review |
Brian Mitchell |
| Posted on Wednesday, November 19, 2003 - 07:28 pm: |
Blueroom Minipod/Cinepod 5.1 Home Theater Speaker System Is it a speaker or a conversation piece? When you first see the Blueroom minipod speakers, you can't be so sure. Well, of course they are speakers. The minipods offer contemporary styling and exceptional clarity in a compact speaker system which doesn't look like a normal boxed speaker. Cool, colorful speakers When I first saw pictures of the minipods, I thought what a cool looking speaker. When my girlfriend saw them she loved the way they looked, and affectionately called them "little cute telletubbies". We chose to get them in red, however they are available in 10 different colors. Small and stylish The shiny red speakers arrived in perfect condition -- 4 minipods (mains and surrounds), 1 cinepod (center speaker) and 1 bass station. I initially thought the speakers were larger, but they really are small bookshelf sized speakers just over a foot tall. Please note these speakers should be placed on 26"-43" stands or shelves and should not be placed on the floor. The minipods were also much lighter than I had expected, weighing only 5.5 lbs (2.37Kg). They come with three sputnik metal spikes, which basically provide an elevated 4-inch stand and add to the speakers futuristic, George Jetson cartoon-like appearance. The egg-shaped bass station is small in comparison to most subwoofers, and it resembles an old fashion outdoor charcoal grill. It features a 10-inch upward firing subwoofer and an internal 75-watt amplifier. Odd connectors Both the minipods/cinepods have less common spring loaded speaker wire binding posts, which will accept heavy guage (thick) bare wire, banana plugs or pin connectors. The cinepod has dual inputs for bi-wiring/amping, however the speaker terminals are so close together only bare wire can be securely connected and wedged into place. 4 ohm considerations Both speakers are rated at 4 ohms / 90db sensitivity. However, even the budget priced Yamaha RX-V740 receiver had no problem powering the pods. The minipods are recommended to be used with amps rated 10-100 watt RMS. But I witnessed no problems from using a 200-watt per channel Sherbourn amp. The minipods seemed to utilize all the power they could get, revealing even more depth and dynamics. However, you still want to make sure your amp/receiver can handle a 4 ohm load without overheating. Center speaker shines Finally the most important part of any speaker system, the sound quality. I was continually amazed how well this system sounded for music and non-action movies. The cinepod center speaker offered exceptional detail and transparency with voices and musical segments. You don't realize how much you are missing from a weak center speaker, until you hear a good one. The cinepod is just that! At $399, it is well worth the cost and one of the best I have heard at this price point. It almost made me wonder how a system of 5, or even 7 cinepods would sound together. Sweet sounding music The minipods are nothing to scoff at either. They feature a single 5" kevlar cone and 1" neodymium tweeter, while the cinepod benefits from two 5" kevlar cones. As main speakers (left/right), the minipods provided pin-point imaging, while maintaining a huge soundstage for stereo music. I was especially impressed how well they sounded for their size. The midrange was clean, tight, crisp and dare I say quick. The sound gave off an airy, relaxing quality I found quite pleasing while listening to Dave Brubeck and Dave Matthews. Although, you still need a subwoofer to complement the low-end bass. No boom The bass station is unfortunately the weakest part of the Blueroom system. It doesn’t distort or draw attention to itself, but it just can’t create deep bass. To its credit, the bass is quick and tight and thankfully not boomy, even though I had it cranked almost all the way up. It is better suited for music listening and small rooms. I suppose your neighbors may thank you, but you will miss out room rocking explosions from movies and the pulsating beat from techno, hip-hop or rap music. Maybe I am overly critical of such a small subwoofer, with just a paltry 75-watt amp. At an MSRP of $699 you can find comparably priced subs that will do a much better job. Surrounded by pods Using direct radiating surround speakers, such as the minipods, ultimately comes down to personal preference. I find direct radiating speakers often sound better for multi-channel DVD-Audio or SACD. Although, for movies it is a toss-up and depends on the speakers and placement. I had the surround minipods placed at the sides of my 16-foot wide room on 48-inch stands. The minipods again performed well as spacious sounding, detailed surrounds, which also exceeded my expectations. Identical speaker recommendation The best part about using the same speakers as mains and surrounds, is that front to rear sound effects maintain the same timbre and tonal accuracy. This creates a seamless surround effect, which is much harder to equalize/calibrate with different types of speakers. Using different speaker brands even further complicates matters and usually leads to less realistic sound. This is just a couple of the reasons why I am a big advocate for using identical speakers for all channels, especially when the installation calls for small sized speakers. Package it up You could purchase 5 minipods ($250 each) as I have suggested above, however the cinepod ($399 each) is so good as a center speaker, it is worth the extra $149. The total package price of the system with bass station (subwoofer) I tested is priced at $1899 at the Blueroom website. All speakers can be purchased individually, so you can buy as many as you need. Therefore, you don’t have to purchase the bass station. Then again, Blueroom offers a 30-day money back guarantee so if you don’t like it you can always return it. Flaunt your style The bottom line is you have to like the look of these speakers to buy them. If so, you can have a home theater speaker system that doesn’t take up much space that looks and sounds incredible. Finally, style conscious consumers have a unique alternative to traditional speakers. So, if you need to replace the speakers your wife (or significant other) can’t stand, these could be the ticket. Just make sure you choose the right color . You will definitely want to show these off! Pros Style and contemporary design Excellent sound Spacious soundstage Pin-point accuracy Detailed midrange and highs Perfect timbre match for all channels Center speaker detail Cons Subwoofer lacks low-end bass Spring loaded speaker connection posts Speaker grills extra http://www.blueroomstore.com/minipods.html http://www.blueroomstore.com/cinepods.html http://www.blueroomstore.com/bassstations.html Test Equipment: Sherbourn PT-7000 Preamplifier & 7/2100 Amplifier Yamaha RX-V740 Receiver Yamaha DVD-C920 Five Disc DVD Changer Better Cables Audio/Video Cables Eighth Nerve Acoustic Room Treatments AVIA Guide to Home Theater Calibration DVD Remember I am just one man with one opinion. If you own this product, or have a comment or question feel free to add your thoughts below. Brian Mitchell Founder & CEO eCoustics.com |
Jerry |
| Posted on Tuesday, December 02, 2003 - 03:58 am: |
They look like copies of the B&W bookshelf speakers, and the woofers in the satellites look like the B&W woven carbon fiber drivers you can buy in the speaker catalogs like Parts Express. |
Anonymous |
| Posted on Tuesday, December 02, 2003 - 04:14 am: |
From the Blueroom Website
Quote:Blueroom was born in the engineering labs of B&W Loudspeakers by the same designers who created the renowned Nautilus tower speaker. In 1997, Blueroom became its own company under the control of B&W's former President, Robert Trunz. Mr. Trunz’s vision for Blueroom is to make these superior designs available in an affordable format. To that end, Blueroom is dedicated to developing speakers that integrate form and function with a cyber-organic aesthetic; and this under the premise of a price which allows everyone to share in the best of latest technology and design.
Anonymous |
| Posted on Tuesday, December 02, 2003 - 04:48 pm: |
I think I would have a hard time justifying spending almost $2000 on a 5.1 set of speakers that only includes a 75watt 10inch woofer. and even 250$ per speaker for the minipods seems like quite a bit of cash. I suppose it makes sense for the audiophile who is also ultra fashion conscious, but I'm pretty sure if one ignored form that there are much better deals to be had. |
James |
| Posted on Monday, December 08, 2003 - 01:11 pm: |
I've had 5 minipods for almost 3 years now. They were only $200 each when I bought them and I consider it money very well spent. I'm not going to bother with a cinepod as the minipod I've been using as a center has performed perfectly. The bass station is another matter entirely. I ended up going with a Apieron Audio S-8 for $400 instead and after some tweaking I couldn't be happier. In the end I'd call them $200 speakers with a $50 cool design tax tacked on. |
