Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > How to connect 2 amps from one mixing...
Author Thread: How to connect 2 amps from one mixing desk???
Username: Dawnbeaver
Connecting two amps from one mixer???
How to wire two amps off one mixing desk? Can anyone help me. Amp1 is Peavey 8.5c with no "record out", amp 2 is Alesis Matica 900 also with no record out. The mixer has a record out but I'm using this for the monitor amp. Do I just use piggyback rca plugs at the desk master out?
Username: Soccer
Post Number: 242
Use "Y" adapters for each mix deck output
Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > How to connect 2 amps from one mixing... [ « Previous ] [ Next » ]
