Thread: ProAc Tablet 8 |
New member Username: Stratguy
Post Number: 7 Registered: Jul-04
| Posted on Friday, July 23, 2004 - 10:26 pm: |
In my quest for a great sounding stand-mount, I have come across these little gems. Why is it that I can't find any discussion about them here or on Audiogon, or Speaker Asylum, or anywhere? What's the deal? Anyone? |
Post Number: 8 Registered: Jul-04
| Posted on Friday, July 23, 2004 - 11:37 pm: |
Maybe if I spelled Tablette correctly!! Does anyone have experience with these little guys? |
J. Vigne Unregistered guest |
| Posted on Friday, July 23, 2004 - 11:54 pm: |
ProAc is a very good speaker line, little known in the States. They do take some system balancing to get the most from any of their speakers. They tend to the slightly bright analytical side. |
Post Number: 9 Registered: Jul-04
| Posted on Saturday, July 24, 2004 - 12:05 am: |
J. I heard them today. It's hard to believe that much sound was coming from one of the smallest speakers I've ever seen. I need to spend some more time with them. As you can see, my $500 budget has crept up to $1200. |
| Posted on Saturday, July 24, 2004 - 12:34 pm: |
Steve, if you're working your way up to the $1000+ range look at the reivews for the Spendor S3/5. Not very efficient but I've run LS3/5a's off my Mac tubes with 40 watts per side and done quite well. Just put "Spendor S3/5" in a search engine.
