Thread: HOw to Hook it up |
Bronze Member Username: Rickypearson
Post Number: 34 Registered: May-04
| Posted on Friday, July 23, 2004 - 04:39 pm: |
On the back of my EQ there are 4 red and white RCA cabels can u tell me were these go on the back of my receiver |
J. Vigne Unregistered guest |
| Posted on Friday, July 23, 2004 - 11:38 pm: |
Usually they go from tape out to the EQ and from the EQ to tape in. You simply make a loop with the EQ in the middle and then engage the tape monitor to have the EQ in circuit. |
Post Number: 35 Registered: May-04
| Posted on Saturday, July 24, 2004 - 01:00 am: |
By doing that does it only allow me to EQ the Tap or the Hole system? |
| Posted on Saturday, July 24, 2004 - 12:12 pm: |
If you place the tape deck in the loop downstream of the EQ you will EQ tapes and the whole system. Of course, if you put EQ on the tape as you record you will then have to un-EQ the tape when you play back or you will be doubling your changes. This loop also makes the process of playback more complicated if you have a three had tape deck. If your pre amp has the ability to do tape to tape dubbing between two decks you can place the EQ in tape one and the deck in tape two. This will allow tape EQ and playback with minimal fuss. |
Post Number: 36 Registered: May-04
| Posted on Sunday, July 25, 2004 - 01:34 am: |
Awsome awsome, I actuly dont have a pre amp So iam just going to Loop it through my Tape deck and that shall do me good for the system, Thanks alot of the Answers man |
Tech Pro Unregistered guest |
| Posted on Sunday, July 25, 2004 - 08:30 am: |
Why do you need an equalizer anyway? |
Silver Member Username: Sun_king
Leeds,
West Yorkshire
UK
Post Number: 152 Registered: Mar-04
| Posted on Monday, August 02, 2004 - 06:38 pm: |
They are helpful for adding bass if listening at low levels. Not all receivers have loudness buttons.....only the cheaper ones seem to do. |
New member Username: Sause
Post Number: 3 Registered: Oct-04
| Posted on Wednesday, October 27, 2004 - 01:08 pm: |
Do most receivers now have a tape monitor now? |
| Posted on Sunday, December 05, 2004 - 09:35 pm: |
Please e-mail me the schematic for the Pioneer BP520 Equalizer. It has two hot wires on it and I'm not sure why. Please tell me why. Thanks |
| Posted on Tuesday, December 28, 2004 - 03:45 pm: |
i got n old school pioneer sx 838, n im trying to hook up a pioneer sg 540 graphic equalizer to it how do i do that, i have no phono player nor a tape deck, can i some how run it through my reciever, to listen to fm stereo, if so please explain ti me how in detail lol, |
| Posted on Thursday, January 27, 2005 - 09:29 pm: |
I am trying to connect an old style Fisher (10 control levels) Graphic Equalizer to a Sherwood Amplifier that I purchased recently. I also want to be able to use my dual casette recorder which I have conntected to the amplifier. The amplifier has color coded connections and the equalizer does not. Can you help me with directions to make the connections I need. Thanks, Jim Dalton |
Bronze Member Username: Usa2k4
Post Number: 51 Registered: Dec-04
| Posted on Thursday, January 27, 2005 - 09:39 pm: |
@ fallsinquestion: Very few Dolby Digital AV receivers have the tape monitor loop. On some that do such as the Panasonic SA-XR50, the tape monitor loop can only be enabled when used with analog sources and it'll be automatically disabled when a digital source is switched on. |
TAnderson Unregistered guest |
| Posted on Tuesday, March 01, 2005 - 10:43 am: |
Need instructions for tape-to-tape copying: I have a Pioneer CTW 503 R dual cassette tape deck, and cannot find the instructions for tape-to-tape recording. Neither of us can figure out the proper sequence of buttons... and no teenagers at home to make it work. |
New member Username: Shagnasty
Tallahassee,
FL
Usa
Post Number: 1 Registered: Mar-05
| Posted on Monday, March 07, 2005 - 08:58 pm: |
How do I hook my EQ to my home stereo for tv and music option? my receiver has no tape moniter button ?
Samuelle Unregistered guest |
| Posted on Saturday, September 03, 2005 - 06:07 pm: |
I have been giving this a lot of consideration and I can't make up my mind. What are your thoughts? Which one has a better deal Dishnetwork or Directtv? |
