Thread: Micro HiFis |
| Posted on Thursday, July 22, 2004 - 07:00 pm: |
Hola! I have searched, yet could not find a decent set of unbiased comparative reviews of Micro Hi-Fi systems. Ironically, Mini Hifi's are too big for my needs, and i'm after a micro. I'd thoroughly appreciate it if anyone would be able to help me with this. My needs/wants: 1) Must play CD-R (perhaps CD-RW) 2) Preferably atleast 3CD Player 3) Have good sound (of course!) emphasising on Bass. Maybe allowing for a seperate sub-woofer. 4) If possible i'd like also for an intergrated DVD player, though that's just me being selfish. My price range is up to £300 If anyone has any recomendations, thank you! |
New member Username: Baronbrazil
Rio de Janeiro,
Rio de Janeiro
Brazil
Post Number: 2 Registered: Jul-04
| Posted on Saturday, July 24, 2004 - 01:13 pm: |
HAVE A LOOK AT : JVC-FSS77B ===> radio circuit ==U$ 200,00 . http://www.circuitcity.com/display_review.jsp?BV_EngineID=cceiadcmdjldhlgcfngcfk mdffhdffo.0&b=b&c=2&catoid=-8022&BV_SessionID=%40%40%40%400509875027.1090688866% 40%40%40%40&OID=90577&BV_UseBVCookie=yes . 5 CD Changer plus RADIO AM/FM AND DVD I have just bought it and as far as I'm concerned it's OK....Although I'm not very fussy as sound goes. Problem DVD REGION 1 REGARDS
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 441 Registered: Dec-03
| Posted on Thursday, August 05, 2004 - 11:39 am: |
Sony CMT-L1 is good looking and sounds good too - you will love the way it looks - sleek and modern. Can be hung on a wall as well. Google search for it. |
Glendale,
CA
US
Post Number: 442 Registered: Dec-03
| Posted on Thursday, August 05, 2004 - 11:40 am: |
Denon makes good ones too - with DVD capability. |
