Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through July 26, 2004 > Speaker connection : Elementary ?
Author Thread: Speaker connection : Elementary ?
Username: Seamus
Post Number: 36
Can 2 independent systems (source & amplification) share the same set of speakers ?
OK, here's the question in more detail :
If I have a 5.1 home-theater system, and decide to get a separate stereo system for dedicated music use, can I connect both the receiver and stereo amp to the different pairs of binding posts on the front speakers simultaneously without frying one or more components ?
Having the speakers connected permanently to both the receiver AND the amp would ensure that I do not have to switch the wires every time I use one or the other system (temporary solution till dedicated speakers for the stereo system are obtained). Of course, only one system will be in use at a time.
J.Vigne
Having the speakers connected permanently to both the receiver AND the amp would ensure that I do not have to switch the wires every time ... because both systems will be fried. Don't do this.
Username: Seamus
Post Number: 37
Thanks Jan. Succinct, as always!
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through July 26, 2004 > Speaker connection : Elementary ? [ « Previous ] [ Next » ]
