Thread: Need some help - NAD 1700 and NAD 2700 THX |
New member Username: Markfsanderson
Tomball,
TX
Post Number: 2 Registered: Jul-04
| Posted on Monday, July 19, 2004 - 02:19 pm: |
After a couple of years out of the A/V hobby, I've made a few purchases of new and used equipment. NAD C541 CD Player NAD 1700 Pre-Amp NAD 2700 THX Power Amp Mirage Omni 60 Book Shelf Speakers (I ran into a great deal - couldn't resist $200/pr @ Tweeters) PSB Image 4t Vampire I/C So far so good . . . everything works as I hoped and I love the sound. Problem is that I don't have manuals for either the 2700 or 1700. The 1700 in particular has something in the front called 'EPC' or something like that - and they coresponding outputs in the back via RCA jacks(is this for driving sub-woofers?) Any info on this would be appreciated! Also, does the 1700 have the facilities to do bi-amping? Right now I only have the 2700 hooked up to my speakers. Any help on locating a manual and/or help here would be greatly appreciated! Thanks! Mark F. Sanderson |
Silver Member Username: Kegger
MICHIGAN
Post Number: 946 Registered: Dec-03
| Posted on Wednesday, July 28, 2004 - 12:10 pm: |
have you tried the nad website most of the time you can download the manuals in a pdf format to be read by acrobat reader "adobe" |
Marco van den Hout Unregistered guest |
| Posted on Friday, October 14, 2005 - 02:12 pm: |
EPL is for external processor loop, for example to hook up an external equalizer. You can also connect a line level device (cd-player) to the EPL inputs and when you press the EPL button on the front you will hear the sound from that device. |
