Thread: Help: Paradigm, Klipsch or PSB speakers? |
New member Username: Robert169
Post Number: 3 Registered: Jul-04
| Posted on Sunday, July 18, 2004 - 11:35 pm: |
Hello audio enthusiasts, I need some help. I am looking at getting 5.1 audio that will sound good with both movies and music. I watch lots of movies and listen mostly to rock, both older and modern. Also some dance music, techno, etc. I am looking at pairing a Yamaha receiver (either the RX-V1400 or 2400) with either: Paradigm Monitor 9 floor standing fronts PS-1000 subwoofer CC-170 center ADP-170 rear surrounds Or Klipsch RF-25 floor standing fronts RW-12 subwoofer RC-25 center RS 25 rear surrounds I am also planning to listen to PSB’s new Image Series line when they get to the store by me. They are supposed to arrive within a few days. I understand the Paradigms above may not be matched perfectly. The CC-170 may be a little small matched up with the monitor 9s. I wonder if that center channel would be enough when in a movie with a battle type scene with dialogue? What do you all think of these options? Recommendations? Thanks
Silver Member Username: Elitefan1
Post Number: 502 Registered: Dec-03
| Posted on Monday, July 19, 2004 - 09:22 am: |
I would change your Paradigm lineup to the Monitor 7 for fronts and then get the cc-370 for the center. I have always liked the 7 better than the 9, tighter bass,less boomy and the cc370 is a very good center. I would not consider the Klipsch with Yamaha. The 1400 and 2400 are much better than previous models but still a bit thin and not a good match with the very bright Klipsch. Listener fatique will set in very quickly. Do listen to the PSB's and then choose between them and the Paradigm's. |
Post Number: 6 Registered: Jul-04
| Posted on Tuesday, July 20, 2004 - 01:43 pm: |
Thanks realelitefan. Other recommendations are welcome.  |
