Home > Message Board > Home Audio > Subwoofers > Archive through August 01, 2004 > Help! Can't extract toy-blocks from ...
Author Thread: Help! Can't extract toy-blocks from subwoofer
Username: Pdemling
Greetings,
My (toddler)son has managed to dump several of his small toy blocks into the opening of the 100W subwoofer on my Samsung HT-DB600 (which I love). I've tried shaking them out, but apparently the tube is snaked inside, so this has proved unsuccessful. It's particularly irritating to hear them rattle around in there when Isildur cuts the One Ring off of Sauron's finger. :-)
So what do you think - is it okay to pry the top of the SW off, or will this damage the unit, in which I case I should pay a professional to do it? Perhaps I could fish them out somehow?
Any suggestions are appreciated!
thank you,
-Peter
Username: Kegger
MICHIGAN
Post Number: 791
if you can get to the speaker/driver you can remove
the screws around the edges and take out the driver/speaker.
that way you should be able to find whatever is inside
the cabinet.
Home > Message Board > Home Audio > Subwoofers > Archive through August 01, 2004 > Help! Can't extract toy-blocks from ... [ « Previous ] [ Next » ]
