Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Can I adjust my autoprotect on marant...
Author Thread: Can I adjust my autoprotect on marantz SR7400
Username: Ketchupaholic
It seems like it kick in way to early. Any of you out there know if I can adjust it so I can turn the volume up higher.
For Speakers, I have Bowers & Wilkins (B&W)
Front : DM604 S3
Center: LCR600 S3
SW: ASW 650
Rear: DM602 S3
Any help would be appreciated.
Username: Sun_king
Leeds, West Yorkshire
UK
Post Number: 123
No, you can't. It may be faulty and need looking at but other than that, you are perhaps asking the amp to drive too many or too high resistance speakers. Check the amp specs and your speakers specs to make sure everything is ok.
Username: Audiophiliac
Boise, ID
USA baby
Post Number: 9
how loud are you talking? regardless, you should be able to crank it all the way with those speakers and blow them before the amp gives up. There was a productions run of 7400s that had the A/B bias set wrong, causing the amp to run extra hot and shut down for thermal reasons. Call them with your serial number and see if they will replace it. You can also adjust the bias pots if you know how. :-) Good luck!
Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Can I adjust my autoprotect on marant... [ « Previous ] [ Next » ]
