Thread: Using 5 ohms 250watts sub.with 100 watts 8 ohms receiver. |
New member Username: Subabu2002
Erode,,
Tamil nadu,i...
India
Post Number: 6 Registered: Apr-04
| Posted on Thursday, July 08, 2004 - 06:24 am: |
hi, i have yamaha subwoofer yst sw320. my receiver is pioneer vsx d-711 having 100 watts with 8 ohms. but my subwoofer is 250watts with 5 ohms. i used it for past 2 months still now it had no problem. does any problem will happened in future while using this sub with pioneer amp.? thanks suresh babu(india)
KYjERRY Unregistered guest |
| Posted on Tuesday, July 13, 2004 - 12:25 am: |
You should be okay. Your receiver's capable range should be between 3-10 ohms. If anything your pioneer will be working harder thus shortening the life (If you want to look at it that way). But Pioneer is a good brand and I don't think it would affect it that much unless you really push the receiver a lot. |
| Posted on Tuesday, July 13, 2004 - 01:14 am: |
If your sub is self powered, this is not even a concern. If your Sub is connected to the LFE out connector on your pioneer receiver, and it is an RCA type connector, it means your sub is self powered, and impedance is a non issue. |
Erode,,
Tamil nadu,i...
India
Post Number: 8 Registered: Apr-04
| Posted on Wednesday, July 14, 2004 - 11:45 am: |
thanks to all.. suresh babu
