Thread: A 6 ohms and a 8ohms speaker hooked up together ???? |
New member Username: Gc2410
Post Number: 1 Registered: Jul-04
| Posted on Wednesday, July 07, 2004 - 11:47 am: |
Hi, Please can somebody help me out? I have a Yamaha RX-V1050, (old, but still perfectly working). This amplifier has the possibility to connect 2 pair of speakers. on speaker connection "A" I already have a pair of speakers that work through an external active equalizer. I use these speakers when I'm in my music room. My question is: I have another two pair of speakers. On set has a 6 ohms impedance and the other set 8 ohms. I would like to try and hook up together to my speaker connection "B" (in guess it's called "in paralel"??) Is it possible to connect a 6 ohms speaker with a 8 ohm speaker? Would this damage the speakers or amp? Thank you guys |
Silver Member Username: Kegger
MICHIGAN
Post Number: 729 Registered: Dec-03
| Posted on Wednesday, July 07, 2004 - 11:53 am: |
amp! |
Post Number: 2 Registered: Jul-04
| Posted on Wednesday, July 07, 2004 - 11:59 am: |
Well.....I told you it was old. Sorry but this is what I have right now.
MICHIGAN
Post Number: 730 Registered: Dec-03
| Posted on Wednesday, July 07, 2004 - 12:02 pm: |
you asked would it damage the speakers or amp. it won't hurt the speakers. but will probably fry the amp! |
Post Number: 3 Registered: Jul-04
| Posted on Wednesday, July 07, 2004 - 12:14 pm: |
Thanks KEGGER. |
| Posted on Monday, July 19, 2004 - 08:45 pm: |
My speakers are 60+60 watts (^ ohms) can I change these 2 speakers for better ones ???My power output is 120_10,000HZ 60 watts per channel |
