Home > Message Board > Home Audio > Equalizers > Anyone find merit in using graphic eq...
Author Thread: Anyone find merit in using graphic equalizer in a stereo set up?
tinman
i am thinking of adding a 10+10 analog graphic equalizer to my stero set up. my listening room has lousy acoustics and i thought maybe an equalizer would help.any advice??
G-Man
Equalizers can be great. But good equalizers are expensive. A good equalizer will balance out the frequencies and db's in the room when operated properly.
Ideally, you can get a local dealer or ISF technician or some sound technician to bring over their high quality equalizer and balance and equalize your speakers in relation to your room.
Then they can take it back home.
swampcat
Try moving your speakers around , closer to corners for more bass, away from corners and walls for less bass. Toe them in or out ect. Speakerstands? (Raise off floor to ear level). I would try EQ last.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Equalizers > Anyone find merit in using graphic eq... [ « Previous ] [ Next » ]
