Thread: Looking for some Semi "Bright" bookshelf speakers |
New member Username: Bleu_allen
Pensacola,
Florida
Post Number: 7 Registered: Jun-04
| Posted on Friday, July 02, 2004 - 10:47 pm: |
I have been thinking of the new infinity beta 20's or maybe axiom's bookshelf. Any thoughts. I want a detailed extended treble and tight bass. My reciever is a slightly warm Harman Kardon two channel hk3480 120 watts per channel with 8 ohm impedance. |
Silver Member Username: Kegger
MICHIGAN
Post Number: 631 Registered: Dec-03
| Posted on Saturday, July 03, 2004 - 02:27 am: |
well jbl and klipsch are definatly bright speakers. i am running an hk reciever. and klipsch do very well for me. but i would go listen to anything someone suggests and certainly when it comes to klipsch "their not for everyone" and from my personal experiance the cheaper lines you generally find at best buy type stores don't cut it for me. generally when it comes to jbl and klipsch you need to get close if not right at their reference or top of line models.or their just not very good. |
Unregistered guest |
| Posted on Sunday, July 04, 2004 - 07:26 am: |
Perhaps we are confusing the term "bright" for "harsh"? Your H/K reciever is not "warm" although it probably runs a tad hot. It simply has more current capability than many other recievers making it sound "fuller" by providing what the speaker is demanding: CURRENT. Lots and lots of harsh speakers out there.......you should have NO trouble finding a pair. Here's a hint: bring some old Janis Joplin records for evaluation. Don't buy any speaker system that makes Janis sound good, as these would NOT qualify as "harsh" or "bright" or "good" for that matter. My question is this: "Why are you looking for crappy speakers?" |
MICHIGAN
Post Number: 649 Registered: Dec-03
| Posted on Sunday, July 04, 2004 - 01:33 pm: |
there he goes again throwing his what he percieves as superior knowlage around again. and blasting someone for having a different oppinion from his. anyway Bleu Allen many people on these boards will tell you that h/k is warm and usually pair bright speakers with them. so if that is what you like than don't listen to these guy's that try to tell you how it is.and that no your wrong and do it this way or your dumb and i'm smart. as there are many types of music and speakers that sound better to others but not all.not to mention some speakers can do a better job on some music than others do. and you aren't less educated in how to listen to music because you like something different than someone else. i believe that is why we have choices and preferences!
Pensacola,
Florida
Post Number: 8 Registered: Jun-04
| Posted on Sunday, July 04, 2004 - 07:03 pm: |
I guess the term "bright" is somewhat of a misnomer. What I am looking for are speakers that sound good with my Hk3480 stereo reciever and are not deficient in the upper frequency range I want a speaker that does a good job with the detail in that regard. I have a Harman Kardon receiver not a Yamaha. I am not into a harsh sound at all. That is why I am asking about the Infinity Beta series and the Axiom's. BTW... I'm not sure any speaker would sound good with Janis Joplin.
| Posted on Monday, July 05, 2004 - 12:43 am: |
Here's a couple you might try to audition: 1) Paradigm Reference Studio 20 2) JMLabs Chorus 707 S |
| Posted on Monday, July 05, 2004 - 10:06 pm: |
Bleu Allen, The best case scenerio is to listen to speakers in your room on your H/K. I agree you should look into the Paradigm line. Decent build quality, decent x-over. Don't fall for the extra cost of the side panels though, they still sound the same. Axiom's appear to have some crossover problems, which would be very audable with old, harsh recordings. By the way, it's a good idea to bring some old, harsh recrdings in when auditioning speakers. They might tell you more about the speakers problems than reference recordings. You might also look into buying used speakers. Can get a much better value used. The older A/D/S line were great speakers(L710, L-620 etc), and you can pick them up used reasonably. Some of the B&W's might work for you. Parts Express makes some speaker kits that are pretty impressive for pretty cheap, if you can use a soldering gun. I'd stay away from 3 or 4 way designs. The less crossover points you have, the better. Theres no substitute for good drivers, good, quiet cabinet's and properly designed crossovers. In the end, if you look and listen long enough, you'll end up with that type of speaker system. P.S. There ARE speakers that make Janis Joplin sound good. |
MICHIGAN
Post Number: 695 Registered: Dec-03
| Posted on Monday, July 05, 2004 - 10:21 pm: |
very well written post maui. not that you need to please me by anymeans. but i liked the post none the less. and i would second maui's recomendation on the partsexpress kit's as have built some. also have allways found b&w speakers very pleasing to the ears. |
Silver Member Username: Elitefan1
Post Number: 473 Registered: Dec-03
| Posted on Tuesday, July 06, 2004 - 04:55 pm: |
Bleu, How much do you want to spend and do you have any size restrictions? |
Pensacola,
Florida
Post Number: 9 Registered: Jun-04
| Posted on Tuesday, July 06, 2004 - 10:27 pm: |
The room size is 11.5' x 14.5' with berber carpet. It doesn't need to shake the house. Also, the speakers will be on 30" metal stands. Just want real good detailed sound. Can spend about $300-400max. per pair. thanx |
Post Number: 474 Registered: Dec-03
| Posted on Wednesday, July 07, 2004 - 10:12 am: |
Bleu, Ckeck out the Monitor Audio Bronze B2. List is $399 and I've seen it at Downtown Audio's website for $299. Match's well with H/K. I recently bought the B1's for my kitchen and they sound great with my Elite receiver. |
