Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through July 26, 2004 > Building speakers, i need help with o...
Author Thread: Building speakers, i need help with ohms..
Username: Delirium
Post Number: 12
I would like to build some bookshelf speakers or maybe floorstanding speakers. I know that my receiver puts out 85 watts at 8ohms. Well one midrange is 8 ohms, and one tweeter is 8 ohms. So I can wire them to get either 4 ohms or 16 ohms right? So how can I get my bookshelf speakers to have the correct ohms? (8ohms)?
Imagine if I wanted two midrange and one tweeter (all 8 ohms).. how would I get 8 ohms out of that? Any help is appreciated... thanks!
Username: Timn8ter
Seattle, WA
Post Number: 121
Why is 8 ohms correct? Your receiver may perform better with a higher load. If you have a typical solid state amp 4 ohms is not going to hurt anything. Quite often when someone is building an MTM they will purchase 16 ohm drivers to wire in parallel for an 8 ohm load. Keep in mind that these numbers are the nominal load and do not accurately reflect the resistance changes that occur at different frequencies. You haven't mentioned how your crossover is going to affect things either. Anyway, in your case, go ahead and wire for 4 ohms. You'll be fine.
Username: Natediggidy
Baltimore, Maryland
U.S.A.
Post Number: 33
When used with a proper crossover, your speakers will present an 8-ohm load to your receiver. It works out this way because the crossover raises the mid's impedance above it's crossover point and raises the tweeter's impedance below it's crossover point. This is kind of oversimplifing, but the mid (or woofer) and the tweeter aren't playing the same thing at the same time so the impedance dosen't drop like wiring two of the same speakers in parallel.
Username: Kegger
MICHIGAN
Post Number: 630
nathan is correct! i think timn8ter missread your
post.
but yes if you build a crossover that your mid
only gets the mid frequencies and your tweeter
only gets the treble frequencies.
than when the music plays mid frequencies it will
go through the midrange speaker which is 8 ohms.
and when it plays treble frequencies it will go
through the tweeter which is 8 ohms.
keeping your curcuit at an 8 ohm load.
like nathan said this is breaking it down much
simplar than it is. but it should give you the
general idea.
Username: Timn8ter
Seattle, WA
Post Number: 122
Yep, sorry about that. I glazed right over the fact we're talking about a 2 way system. I was assuming it was that same old "ohms" questions that gets asked so often. It's right up there with the "watts" question. Speakers are dynamic, not static, so the load changes considerably depending on the frequency. Also, the watts/ohms rating on most solid state equipment is more about marketing than performance. In tube amps, the nominal load becomes more critical but most are designed with 4 and 8 ohm taps and sometimes with 16. Still, in many cases, a high load is better than a low load and your amp will thank you for providing a twelve ohm load instead of 2 or 3. So, all that said, just go for it!
J.......don't wanna crimp your style or anything, so don't be offended by what i'm gonna tell you. Ok? If you need help with ohms, you really shouldn't be building your own speakers at this point. Get a handbook, like "The loudspeaker cookbook" and learn about drivers, crossovers, cabinets, bracing, Q factors, damping, etc. Anyone can put some drivers in a box, connect them to an amp and get noise out of them. If you want noise, buy Bose. If you wanna do it right, and be proud of what you designed, your gonna have to learn at VERY least, the basic math. This post is not meant to discourage you in any way....rather to steer you in the right direction. No hard feelings, please? If your NOT willing to put the time in to learn the math, go to www.partsexpress.com for some pre-made kits.
J. Vigne
But I know which end of a soldering iron to hold.
Baltimore, Maryland
U.S.A.
Post Number: 42
Umm, J.V., I think he meant the other guy (the original poster) =)
J. Vigne
mybad
Blue Bayou
If I upgrade my midrange speakers from a set of cheap Jap 4 ohm to a better quality JBL (which happen to be 8 ohm), using the same crossover, how will the ohm change affect the sound? By the way, it's a 3 way system. Thanks
Username: Timn8ter
Seattle, WA
Post Number: 123
It's going to sound terrible. Not because of the resistance rating but because you have no idea what you're doing. Crossovers are designed for the particular drivers and the particular application. Since you're obviously clueless about the whole process don't even try. Oh, by the way, the word is JAPANESE.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through July 26, 2004 > Building speakers, i need help with o... [ « Previous ] [ Next » ]
