Thread: PIONEER ELITE 43TX AND DEF TECHS NOT HAPPY WITH EACH OTHER...WHAT DO I DO??>? |
Bronze Member Username: Djtorch
Post Number: 42 Registered: May-04
| Posted on Monday, June 28, 2004 - 06:46 pm: |
I have had the Pioneer VSX-43TX for a few months. It works ok even though it seems like you have to really pump it up to get some some speakers to respond. Well, I finally saved up enough money to get the DEF TECHS BP2002s and a C/L/R 2300. The system at normal volumes sound good. HOwever , when I turn the system up to near zero. The reciever cuts off. I called up Def tech and they told me that's simply the max those 2 pieces will do together. I'm wondering if there is any work around for this problem. The system is loud...but, it' snot that loud. I'm now in a position where I either have to get rid of the Def techs or the Pioneer. |
Bronze Member Username: 514329
Post Number: 14 Registered: Jun-04
| Posted on Monday, June 28, 2004 - 08:33 pm: |
try another reciever or speaker first before u return the others. |
| Posted on Monday, June 28, 2004 - 11:12 pm: |
Hey I have the Pioneer VSX-43TX with Def Tech BP8B's I don't know why you have to go to zero on the volume. I cannot reach -20, so you probably don't have the 43TX setup correctly. Make sure u are setting it to 6 Ohm because Def Tech speakers love 6 Ohm, so when you click the speaker button it should say 6 Ohm Not 8 Ohm. After that adjust all channels to +10 and also use the loudness button, Hi-Bit, DNR, and MCACC button. After that it should change dramaticly, if you need more information e-mail me at furi76@aol.com or call me at 760-898-1654, I am happy to help anyone with Pioneer and Def Tech's cause I have the same. |
Post Number: 43 Registered: May-04
| Posted on Monday, June 28, 2004 - 11:22 pm: |
Thanks for that info. I do have the Pio now set to 6 ohm. However , your other settings I do not. my loudness , Hi-Bit, and DNR are off for sure. But, won't that add more noise (hiss)? |
New member Username: Levike
Cathedral City,
California
Post Number: 7 Registered: Apr-04
| Posted on Monday, June 28, 2004 - 11:46 pm: |
It will add more noise, but you cannot reach zero on the dial, because it will be way too much power. I only reached -11 once for about 2 min, after that my ear were hurting. Hope this helps Need more help e-mail me |
Post Number: 44 Registered: May-04
| Posted on Monday, June 28, 2004 - 11:58 pm: |
Something must be wrong then. Or my ears are in bad shape. I have it at 11 all the time. It's lound but does not hurt my ears. Not even close. |
Cathedral City,
California
Post Number: 8 Registered: Apr-04
| Posted on Tuesday, June 29, 2004 - 02:43 am: |
Hey Also make sure you select LARGE SPEAKER for the fronts and center. What kinda subwoofer are you using? Also press the tone button and adjust the bass and treble. Okay turn on all of these Loudness Button DNR Button Tone and then adjust bass and treble Hi-Bit Button MCACC Button This should make your sound louder and cleaner. Take Care |
Post Number: 47 Registered: May-04
| Posted on Tuesday, June 29, 2004 - 02:58 am: |
OK..I tried some of those. Not noticeable difference. I'll keep trying. I'll give it a few days. If I cannot get them to work right. I'm looking for a good deal on a 2 way for the fronts. if that does not come through...goood bye PIO! |
Silver Member Username: Smitty
Post Number: 110 Registered: Dec-03
| Posted on Tuesday, June 29, 2004 - 07:23 am: |
If DefTech told you the receiver can't power those speakers I would look for something else. You really shouldn't have to set the loudness on, from my experience that's usually for when the volume is set low and you want it to seem 'louder'. Have a look at this thread for some other suggestions with DefTech: DefTech Recevier Suggestions |
