Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Nad C320bee- Solutions to be able to ...
Author Thread: Nad C320bee- Solutions to be able to play 2 pr. of speakers?
Username: Gamecock
The 320Bee that I ordered will be in tomorrow, I overlooked the fact that currently I am driving a 2nd pair of outdoor speakers on my porch with my old Sony receiver. The Nad only has a place for 1 pr. of speakers. What would be some solutions to be able to play the porch speakers ? I only want to be able to play 1 pr. at a time.
Thanks for everyones help.
Username: Sun_king
Leeds, West Yorkshire
UK
Post Number: 107
Use banana plugs to connect the two pairs of speakers. Each time you want to select a different pair you will have to unplug one and reconnect the other. Using banana plugs makes this a simple matter, no bare wires to play with. If you want to do this differently, you could buy a speaker switch, very cheap. With this device you would plug both pairs into it and use a dial to select one or the other. I would prefer the former option as there is less degradation of sound, ie you aren't putting the signal through another device.
Username: Gamecock
Thank you for your help, I agree with you about the speaker switch. The banana plug suggestion will probably be the best solution.
Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Nad C320bee- Solutions to be able to ... [ « Previous ] [ Next » ]
