Thread: Protect mode |
New member Username: Hondadriver22
Post Number: 2 Registered: Jun-04
| Posted on Saturday, June 26, 2004 - 12:37 pm: |
I got an audiobahn mono amp it was in use and the cables going into the + side of capacitor came out, i put them back and amp wont come out of protect mode. there are no blown fuses, what is the prob? |
Silver Member Username: Project6
Post Number: 944 Registered: Dec-03
| Posted on Saturday, June 26, 2004 - 10:21 pm: |
try discharging the capacitor then try again. |
Silver Member Username: Soccer
Post Number: 220 Registered: Apr-04
| Posted on Sunday, June 27, 2004 - 06:49 pm: |
If not, you problably have a protection thermistor blow (acts like a thermal fuse). If this is the case, leave it to a pro. |
