Thread: Pre Reciver? |
Bronze Member Username: Rickypearson
Post Number: 20 Registered: May-04
| Posted on Thursday, June 24, 2004 - 01:51 am: |
Can Some one Explaine what a Pre Reciver Does, and is it worth getting, thanks alot
Silver Member Username: Kegger
MICHIGAN
Post Number: 514 Registered: Dec-03
| Posted on Thursday, June 24, 2004 - 11:24 am: |
do you mean preamp? |
Post Number: 21 Registered: May-04
| Posted on Thursday, June 24, 2004 - 09:11 pm: |
Yeah i sure did lol So whats a Pre Amp |
MICHIGAN
Post Number: 521 Registered: Dec-03
| Posted on Thursday, June 24, 2004 - 09:33 pm: |
a preamp with no amplifiers in it is what you would connect like tape decks or dvd players and such to then connect the amplifier to the preamp outputs. it is simular to a reciever and integrated amp but has no amplifier built in. just an adjustable signal that comes out the preamp outputs a very low signal that goes up and down with the volume control than that very low signal that comes out the preamp outputs connects to an amp that increases the output (amplify). check out this thread it might help! http://forum.ecoustics.com/bbs/messages/1/17643.html
J. Vigne Unregistered guest |
| Posted on Friday, June 25, 2004 - 11:53 am: |
Kegger, move this over to definitons. |
MICHIGAN
Post Number: 524 Registered: Dec-03
| Posted on Friday, June 25, 2004 - 12:15 pm: |
jan i have no problems with this being moved to definitios. but i'm not sure if you mean point this thread their or the other link i gave. or how you would like it done. so you are more than welcome to do what you want so as to get what you want. i don't mean this as hey man you do it! but i'm not sure what actually you are looking for so move it how you like sir. |
