Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Nad power amp question....
Author Thread: Nad power amp question....
Username: Unbridled_id
Chicago
Usa
Post Number: 35
Hello all, I have a question concerning the nad c272 and it's iec connector... On the 120v model the iec has only 2 prongs...no ground.... The lack of a ground prong confuses me, while not essential I would imagine it to be useful... I contacted yawa and talked to a guy there (not the usual one I talk to) and he stated that the lack of the third prong would reduce..interference or distortion, something along those lines.... I also remember someone commenting on audioasylum that the nad c372 has a 3 pronged iec...both integrated and power amp do but only on the 230v versions.... What say all of you about this??
Username: Kegger
MICHIGAN
Post Number: 513
a lot of newer units are coming without the third
prong.
others have a ground release tab of sorts.
and from first hand experience it can have a very
big difference on the amount of noise introduced
into your system.
the ground removed eliminates many noise issues!
and many manufacturers are doing it. so it is fine.
Home > Message Board > Home Audio > Amps > Archive through July 28, 2004 > Nad power amp question.... [ « Previous ] [ Next » ]
