Thread: HMMM FLUANCE? |
DENNIS_G Unregistered guest |
| Posted on Monday, June 21, 2004 - 01:07 pm: |
I never heard of fluance but are they good? I saw some pretty good reviews on the htb-av. I am planning to buy the 10" sub. Their price is relatively cheap. THey also have no specs. Should i take the risk? Help is greatly appreciated |
Silver Member Username: Project6
Post Number: 903 Registered: Dec-03
| Posted on Wednesday, June 23, 2004 - 07:20 pm: |
Go for it...these speakers are still relatively new, but I have tried their HT line up and gave them as a gift for a nephew of mine. They are a very good set of speakers and very well constructed. My nephew loves them. cheers |
Silver Member Username: Disco_stan
Minnesota
Post Number: 154 Registered: Dec-03
| Posted on Thursday, June 24, 2004 - 12:09 am: |
Well Dennis I have the same one and it is awesome for the money, you may never need to upgrade in a long time! I have pushed it to the limits and it is extremely loud with little distortion, but it's a tough sub to bottom out. FYI if you do end getting this sub, check for internal noise. I found some veneer cut outs from the ports on the bottom that were flying around inside. The internal bracing structure was well designed, but there is a bit too much port noise. And when you place the sub in it's new corner, move it around so the sub is atleast a 1 1/2' away from each wall. I found that the sub was too loud if place any closer. Overall this is a great sub for the money and will last a long time. I did email Fluance and they said they will soon the the specs posted, so knowing them...it will take another month or so. Good Luck |
