Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through July 01, 2004 > Yamaha RX-V1400 YPAO and Energy Take ...
Author Thread: Yamaha RX-V1400 YPAO and Energy Take 5.2 speaker setting questions
Username: Geodon005
Mount Prospect, Illinois
I just bought the RX-V1400 and have been enjoying it, but have some questions about speaker sizing. The YPAO setup always sets my front speakers to Large (leaving all others at Small), even though they are a matched set. However, Energy's own manual indicates that the speakers should be set at Large. Should I leave it at the YPAO setting, or manually set the size to Small?
Also, YPAO adjusts the subwoofer output to Both, rather than to Subwoofer alone. Again, which setting would you advise?
Thanks for your help!
Username: Landroval
Post Number: 314
It would be better to set your mains to small. They cant play low sounds so it's useless to feed them with those.
Does both mean that it plays the LFE and the lows from other speakers? If yes, then the both-setting is good.
Username: Geodon005
Landroval:
Actually, the Both setting means that bass is played by the subwoofer as well as all other speakers. If I read your response right, you are saying that my speakers should be set to ONLY play LFE and lows through the subwoofer, right?
Thanks for clarifying. . .
Don
Username: Landroval
Post Number: 315
Yes, it would be better to play the lows only through the sub. This way the speakers wont have to try to play the low frequencies and they can better manage with the mids and highs.
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through July 01, 2004 > Yamaha RX-V1400 YPAO and Energy Take ... [ « Previous ] [ Next » ]
