Thread: Nad 3130 |
New member Username: Buzz23
Wellington Nz
Post Number: 1 Registered: Oct-09
| Posted on Saturday, October 31, 2009 - 05:10 pm: |
my nad 3130 amp turns on but no sound comes out, if its not the fuses, what else could it be? |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 3209 Registered: Feb-07
| Posted on Saturday, October 31, 2009 - 07:07 pm: |
Does the protect light come on when you turn it on? Can you hear the relays click when you power it on? I had a really old, beat up 2150 that refused to turn on. I had it serviced for about 100 bucks and it worked perfectly. |
Wellington Nz
Post Number: 2 Registered: Oct-09
| Posted on Saturday, October 31, 2009 - 07:15 pm: |
yes the light comes on but no clicking sound. It was working fine and i moved my lounge around, reconnected the amp and speakers, it was going then all of a sudden no sound...im hoping its not a big job and hoping i can fix it myself. |
Gold Member Username: My_rantz
Gold Coast Australia
Post Number: 2599 Registered: Nov-05
| Posted on Sunday, November 01, 2009 - 04:35 pm: |
Make sure there are no stray wires that could be shorting on your amps speaker connections. |
Ottawa,
Ontario
Post Number: 3211 Registered: Feb-07
| Posted on Sunday, November 01, 2009 - 06:16 pm: |
That's a good idea. Check you speaker connections. If I recall the 3150 has the old spring-type terminals, maybe there's a short there? |
Wellington Nz
Post Number: 3 Registered: Oct-09
| Posted on Sunday, November 01, 2009 - 06:33 pm: |
ok thanks im going to check that now. |
Ottawa,
Ontario
Post Number: 3219 Registered: Feb-07
| Posted on Tuesday, November 03, 2009 - 07:09 am: |
Any luck Buster? |
Post Number: 2602 Registered: Nov-05
| Posted on Tuesday, November 03, 2009 - 05:40 pm: |
Uh oh Dave, Buster might have really found a short.
Wellington Nz
Post Number: 4 Registered: Oct-09
| Posted on Tuesday, November 03, 2009 - 05:48 pm: |
haha i actually did find a short in the speaker connection. it's going just fine atm. Thanks alot for the help! APPRECIATE it. |
Wellington Nz
Post Number: 5 Registered: Oct-09
| Posted on Tuesday, November 03, 2009 - 05:50 pm: |
u saved me some good money mate. cheers |
Post Number: 2603 Registered: Nov-05
| Posted on Tuesday, November 03, 2009 - 06:06 pm: |
Glad your NAD is okay and you too, Buster. Happy listening. |
Wellington Nz
Post Number: 6 Registered: Oct-09
| Posted on Tuesday, November 03, 2009 - 06:08 pm: |
thanx M.R |
Platinum Member Username: Nuck
Post Number: 13852 Registered: Dec-04
| Posted on Tuesday, November 03, 2009 - 06:17 pm: |
well done, MR. |
Ottawa,
Ontario
Post Number: 3225 Registered: Feb-07
| Posted on Wednesday, November 04, 2009 - 07:19 am: |
Good call M.R. |
