Home > Message Board > Home Audio > Phono > Akai AP-A200 speed uncontrolled
Author Thread: Akai AP-A200 speed uncontrolled
Username: Diabolik
Portugal
I have an Akai AP-A200 turntable and now it have a speed problem.
When is working the speed is uncontrolled, like full speed of the motor, no 33 1/3 or 45 rpm.
The motor I think it is a direct drive one.
I believe it's a problem with the speed sensor, but I don't know how this works in this kind of motors.
Does anyone knows this problem and a possible solution?
Where is the speed sensor on these motors?
Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 14148
The majority of direct drive tables are servo controlled. There's usually a capacitor that hah gone bad in the servo network that will need to be replaced. It's not a job for the inexperienced and you should take the table to a service center where a techinican can perform the repair.
Username: Diabolik
Portugal
Thanks for your reply Jan.
I have checked the two electrolytic capacitors in the Akai, both are ok. I change them anyway but still with uncontrolled speed.
It have several ceramic capacitors, but I didn't change any of these.
More ideias are welcome.
Thanks.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Phono > Akai AP-A200 speed uncontrolled [ « Previous ] [ Next » ]
