Thread: Setting up 7.1 speakers in 20metres length and 20metres width Hall |
New member Username: Tomakali
Chennai,
Tamilnadu
India
Post Number: 1 Registered: Oct-09
| Posted on Sunday, October 25, 2009 - 04:40 am: |
someone guide me how to setup 7.1 speaker systems in our church with 20metres length and 20metres width Hall |
Platinum Member Username: Nuck
Post Number: 13789 Registered: Dec-04
| Posted on Sunday, October 25, 2009 - 07:19 am: |
I must assume that there is a movie night at the church? Is this your standard lovely church with wooden pews and lots of glass? |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 3182 Registered: Feb-07
| Posted on Sunday, October 25, 2009 - 08:04 pm: |
Be fun to listen to music in a room like that. |
Gold Member Username: Petergalbraith
Post Number: 2234 Registered: Feb-04
| Posted on Sunday, October 25, 2009 - 10:34 pm: |
Permanent installation? Or something that gets moved in and out? |
Gold Member Username: My_rantz
Gold Coast Australia
Post Number: 2568 Registered: Nov-05
| Posted on Sunday, October 25, 2009 - 10:51 pm: |
Yes, is it for surround movies, surround music or . . . . . . surround sermons? Try Googling 7.1 speaker set up? Might be a good first move. |
New member Username: Speakerluv
Chatsworth,
Ca
USA BABY!!
Post Number: 3 Registered: Oct-07
| Posted on Friday, October 30, 2009 - 07:07 pm: |
I am just guessing since, tomaklai is in India, I doubt it is a standard church with wooden pews... however, 20mx20m is basically a square room and an easy set up. If we had additional information it would be helpful, and how much you already know..if you are asking a basic configuration; 7.1 are designed to have a Front Right & Left, Rear Right & Left , and at the center of the distance between the front and back speaker an additional pair of speakers (midway). The center channel should go upfront above or below the screen and the subwoofer can go anywhere - what ever sounds best (non-directional sound). This is a very general break down, but with out more information... check out this helpful forum for 5 things you should know about surround sound. http://audiohotspot.blogspot.com/ |
Post Number: 13813 Registered: Dec-04
| Posted on Friday, October 30, 2009 - 08:11 pm: |
Klipch. Maybe Klipchorns. |
