Thread: Amp suggestions |
New member Username: Bdogg
Post Number: 6 Registered: Aug-09
| Posted on Saturday, October 24, 2009 - 05:21 am: |
Hi I was hoping some of you could help me find an amp for a home theater. I need something with 2 channels in the 200 watts per channel or higher range and 4 ohms. I don't know alot about home theaters or amps in general so I would love some ideas/recommendations. Also if you could recommend a surround sound preamp/processor I would be so thankful. Thanks, Brooke |
Platinum Member Username: Nuck
Post Number: 13771 Registered: Dec-04
| Posted on Saturday, October 24, 2009 - 06:31 am: |
Brooke, are you running a 2.1 HT? If not, how will you power the center channel? What speakers do you have now? What size is your HT room? |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 3179 Registered: Feb-07
| Posted on Saturday, October 24, 2009 - 10:07 am: |
Why a 2 channel amp for HT? How about a multichannel setup? http://outlawaudio.com/products/990.html http://outlawaudio.com/products/7500.html |
Gold Member Username: Mike3
Wylie,
Tx
Post Number: 2182 Registered: May-06
| Posted on Saturday, October 24, 2009 - 10:59 am: |
Budget? Will you be mostly listening to music or movies? |
Post Number: 13778 Registered: Dec-04
| Posted on Saturday, October 24, 2009 - 11:31 am: |
We sure need more info |
