Home > Message Board > Home Audio > Phono > How to remove vinyl records
Author Thread: How to remove vinyl records
Username: Icculus
First off, thank you all for the help you provided my last session. I was completely oblivious to the phono world and this place helped out immensely.
I have one quick question.
For some reason, I am under the impression that it is the proper way to store records by taking out the entire paper sleeve from the cardboard sleeve before removing the record. Thus, when I store most of my records the cardboard sleeve could form a 'C' shape with the opening on the right, and the paper sleeve could form a 'U' shape. This forces me to take out the paper sleeve before I remove the record.
I hope this makes sense.
Is this correct? Incorrect? Overkill?
Thank you.
Username: Jan_b_vigne
Dallas, TX
Post Number: 14127
The inner sleeve should have its opening to the top which provides less opportunity for dust to make its way to the disc.
Username: Stryvn
Wisconsin
Post Number: 1183
And less chance for you to pick up the album and have the disc 'roll' out onto the floor
Username: Nuck
Post Number: 13760
Or fall out inadvertantly, as I pass the album to by bro across the kitchen table. Smash goes Ziggy Stardust.
Sigh. Sweep.
Username: Stu_pitt
Irvington, New York
Post Number: 3533
A bit obsessive compulsive...
I have the opening of the sleeve facing up (as Jan said), and the outer plastic sleeve's opening on the opposite side of the cardboard opening.
I also replace the inner sleeves with Mobile Fidelity plastic inner sleeves. Far less static and dust.
Username: Nuck
Post Number: 13763
Seems reasonable on 2 levels, Stu.
1: protection in all manner
2: cannot get at the slab after a few pints, go for cd.
Username: Icculus
Fantastic! Love the discussion and advice. Thanks ;)
Dallas, TX
Post Number: 14133
I assume the plastic sleeve is loose fitting. Otherwise it should be removed all together.
Username: Nuck
Post Number: 13765
More static?
Dallas, TX
Post Number: 14134
Supposedly the shrinkwrap style plastic continues to shrink over time and can warp the disc even when it is properly stored upright at a less than a 5 degree angle.
Username: Nuck
Post Number: 13767
Super, I needed to find a way to be more neurotic.
ty, tyvm.
Username: Stryvn
Wisconsin
Post Number: 1184
For what it's worth, I remember reading such info as a youngster and immediately removing the cellophane from all my lp's.
The beer and other extracurriculars did far more damage than the shrink wrap.
Username: Nuck
Post Number: 13772
sound of a scraping stylus
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Phono > How to remove vinyl records [ « Previous ] [ Next » ]
