Home > Message Board > Home Audio > Amps > Cambridge vs HK
Author Thread: Cambridge vs HK
Username: Tpizzle
Post Number: 566
I am piecing together a living room setup and need a recommendation for an amp. Without having speakers I know it is a tough question, but I am looking for a general answer. I was thinking about spending approximately $450 and am thinking either a Cambridge Azur 540 or HK 3490. What would you guys recommend? Others brands/models are welcome also.
Thanks
Username: Dmitchell
Ottawa, Ontario
Post Number: 3160
If these were you're only two choices I'd take the CA over the HK in a heartbeat. I take it this is for a music only system?
You may want to look at NAD and Rotel integrateds as well.
Deciding on what speakers you want is important, since some speakers don't mesh so well with some amplifiers.
Username: Nuck
Post Number: 13752
db, piecing together means hearache
Username: Tpizzle
Post Number: 567
Its tough investing in something I cant hear first but I live in Montana and have only one hi-fi store within 200 miles, which sells Krell, ML, etc...stuff I can't touch on my budget.
Therefore, I have to go off of recommendations.
I think what I will do is decide on a combo first instead of "piecing," based on someone who already has the combo. Speaker-wise, I am concentrating on swan, monitor audio, totem, etc.
I want to spend around 1k, so I have budgeted around 500-600 for the speaker. It would be for music only and I listen to mostly trance, new age, and soft rock.
Anything you have heard/owned that I could get for around 1k I would be all-ears.
Thanks again
Username: Tpizzle
Post Number: 568
Also, I only have background with AV receivers and have not done a 2-channel setup before. Just to clear up - I need an integrated amp, correct? Just making sure I don't buy something and then need something else.
Thanks again
Username: Magfan
Post Number: 558
db,
Some hi-end stores have all the big stuff but also an 'entry level' hi-end line.
Near me is a store which carries Rotel and another which carries CA as there entry lines. The 'other' stuff stocked includes Krell, ML, Mac, Pass Labs, Naim, Rega, B&W and much else.
Couldn't hurt to call and ask?
If you have the space, being a BIG fan of panels I'd say to write to White Bear Lake Minn. and ask 'em to send you some MMG's on trial. Magnepan will let you try 'em for 30 days, on approval.
Most good 100/side integrated amps should handle these speakers given it doesn't sound like you are a nosebleed loudness type.
Username: Artk
Albany, Oregon
Post Number: 10931
Given you music preference I would consider a pair of used Totem Rainmakers...I think they would be ideal for trance, new age and soft rock. Usually can be had for $500-600 on the used market at Agon.
Username: Jazzman71
Phoenix, AZ
Post Number: 938
db,
While I cannot personally recommend the Rainmakers (have not heard them), I think Art is spot on recommending used on your budget. The fact is you'll get a lot more system, and if you decide something is not for you, you won't take nearly as big a hit when you sell.
Can't afford MF, bah.
http://www.audiogon.com/cgi-bin/cls.pl?intatran&1260114648&/Musical-Fidelity-A3- Dual-Mono-
http://www.audioreview.com/mfr/musical-fidelity/integrated-amplifiers/a3/PRD_115 992_2717crx.aspx
http://www.audioasylum.com/reviews/Integrated-Amplifier-SS/Musical-Fidelity/A3/g eneral/225875.html
Looks like a lot of amp for the money, and has decent phono stages built in if you have or decide to get a turntable.
http://www.audiogon.com/cgi-bin/cls.pl?spkrfull&1260748421&/Soliloquy-5.3
http://www.stereophile.com/floorloudspeakers/459/index5.html
These speakers will also pair nicely with a relatively low powered tube amp if your future explorations take you in that direction. You can also navigate around and find out what others have paired with any amp you are considering.
Note, these are not so much recommendations as they are an illustration of the steps I would take as an approach your situation. Yes, you are a disadvantage not being able to go to a shop and listen, but there is a wealth of information on line. If you are in the States, stick with Audiogon.
Happy Hunting!
Username: Exerciseguy
Fort Hamilton, NY
United States
Post Number: 3014
You can land an HK3490 for under $200 from Harman's eBay auctions, or an 3390, 3485 or 3385 for even less (I recently saw a 3390 sell for about $80!), and if you are on a budget, any is an uncompromised choice; you are as likely to prefer the HK to the Cambridge, IMHO.
http://stores.shop.ebay.com/Harman-Audio__W0QQ_sidZ26519532?_nkw=3490
http://stores.shop.ebay.com/Harman-Audio__W0QQ_sidZ26519532?_nkw=3390
http://stores.shop.ebay.com/Harman-Audio__W0QQ_sidZ26519532?_nkw=3485
Another great budget choice is the Marantz SR4021 for $199
http://www.accessories4less.com/make-a-store/item/MARSR4021/Marantz/Sr4021-Recei ver-80w-X-2ch-Stereo-With-Video-Switching/1.html
or if you want to push the budget a bit, the NAD C725BEE for $599
http://www.spearitsound.com/nad/C725Bee.asp .
Good luck.
Username: Artk
Albany, Oregon
Post Number: 10933
That NAD is a nice little receiver.
Fort Hamilton, NY
United States
Post Number: 3015
If money wasn't an issue, the NAD would be my first choice.
Username: Hawkbilly
Nova Scotia
Post Number: 707
I've heard the NAD receivers head-to-head with Denon's offerings and the Denon's hold up very well. Very good performance on both the audio and video front, and according to the dealer that I frequent the most they've had no reliability issues with them.
Fort Hamilton, NY
United States
Post Number: 3016
I just watched an HK3390 sell for $91 from Harman on eBay.
Username: Artk
Albany, Oregon
Post Number: 10934
That's a good price for a decent product. It would depend on the speakers chosen whether it would be a good match.
Fort Hamilton, NY
United States
Post Number: 3019
...and an HK3485 for $93 tonight.
Username: Tpizzle
Post Number: 569
Those deals are for refurbished pieces though...which I am a little skeptical of. What are your thoughts on refurb equipment?
As long as it is under warranty I guess it's history does not matter.
Username: Tpizzle
Post Number: 570
Also, I shop around on audiogon a lot and now that I am looking at integrated amps I want to make sure I am looking at the right stuff...
For amps, what category do I want to be looking at if I only want 1 piece of equipment (amp-multi, amp-solid, etc)
Thanks
Fort Hamilton, NY
United States
Post Number: 3026
Virtullay all of my gear is refurb., most from the very same Haman eBay store. It is as new, if not actually new as I believe it is.
Username: Hawkbilly
Nova Scotia
Post Number: 708
DB, you probably want to look at int-tran or receiver categories.
Username: Tdogroeder
Des Moines, IA
Post Number: 185
Have you considered Marantz receivers?
Accessories4less sells onkyo & marantz a very good deal, some are refurb and some are new.
http://www.accessories4less.com/make-a-store/category/StereoReceivers/Home-Audio /Stereo-Receivers/1.html?results.per.page=4adf0694
Username: Tpizzle
Post Number: 571
Are Marantz and Onkyo in the same league at any given price? I have heard Marantz is warm sounding, which is what I would like but I never considered them to be competitive with a lower level NAD or mid level Cambridge.
Username: Artk
Albany, Oregon
Post Number: 10949
For HT applications I would prefer Marantz and Onkyo to NAD and Cambridge and I've owned AVR's by all but Cambridge. Music however is another matter. NAD sounds better than any of the above for music to my ears. Marantz is better than it gets credit for though I think...depends on what you expect from an AVR for music.
Fort Hamilton, NY
United States
Post Number: 3027
A bit dated by now, but still a good read.
http://www.homecinemachoice.com/files/reviews/HCC/110_HC_1203.pdf
Username: Nickelbut10
Post Number: 2791
For Home Theater the best I have heard is the new Arcam. Wow. But its pricey. Going back to the comparisons, the friend who just bought the Arcam owned an Onkyo tx806? and prior to buying the Arcam A/B'd it against a NAD T753 in which sounded much better to both my ears, and his compared to the Onkyo for movies and music. The Arcam is what he owns now, and rightfully so as it destroys both. As it should at 6 grand.lol. Just thought I would throw that experience in there.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Amps > Cambridge vs HK [ « Previous ] [ Next » ]
