Thread: Can a home audio system subwoofer be used on a computer sound system? |
New member Username: Fords
Charlotte,
North Carolina
U.S.
Post Number: 1 Registered: Oct-09
| Posted on Tuesday, October 13, 2009 - 10:04 am: |
So I picked up a Yamaha YST-SW030 from a friend of mine who never used it in the home theater system he bought, and I was wondering if it could somehow be used on my computer sound system. I have a small Altec Lansing setup right now, with two small speakers and a medium subwoofer. I'm afraid I don't know too much about how speaker/sub systems work, so advice or directions would be greatly appreciated! |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 3168 Registered: Feb-07
| Posted on Tuesday, October 20, 2009 - 06:06 pm: |
Is the Altec subwoofer powered? How is it connected to the computer? If it's RCA cables you may be able to jut swap out the Altec sub for the Yamaha. |
Charlotte,
North Carolina
U.S.
Post Number: 3 Registered: Oct-09
| Posted on Tuesday, October 20, 2009 - 10:55 pm: |
The Altec Subwoofer needs a power source separate from the computer (plugged directly into the wall). The sub is connected to a control speaker, which connects to the PC via a green cable (Sorry, I don't know the name) that goes to my sound card. I don't think it can be replaced by the Yamaha, the speakers won't work unless the sub is connected. Would there be a way to connect the Yamaha separately? |
