New member Username: Iphonemate1013
ÖĐąú
Post Number: 1 Registered: Oct-09
| Posted on Tuesday, October 13, 2009 - 04:01 am: |
The last year released iPhone 3G. A lot of people choose iphone as their communication tool and entertainment player for its powerful functions. People not only regard it as an phone but also a music and video player. Now I will share my experience to use a useful tool http://www.4videosoft.com/iphone-mate.html 4videosoft iPhone Mate to make use of iphone. http://www.4videosoft.com/images/screen/iphone-mate.jpg The following text will be divided into four parts. First: How to put dvd on iphone? Second: How to convert video for iphone? Third: How to transfer iPhone files to Computer, import PC file or folder to iPhone and transfer files between two iPhones? Fourth: How make ringtone for iphone? Tips: How to make wonderful DVD/video editing (Merging, Trimming, Cropping, Effect adjusting, Capture picture) Before the article, I will explain general knowledge about iphone. Video formats supported: H.264 video, up to 1.5 Mbps, 640 by 480 pixels, 30 frames per second, Low-Complexity version of the H.264 Baseline Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;H.264 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Baseline Profile up to Level 3.0 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats Audio formats supported: AAC, Protected AAC, MP3, MP3 VBR, Audible (formats 2, 3, and 4), Apple Lossless, AIFF, and WAV First: How to put dvd on iphone with http://www.4videosoft.com/dvd-to-iphone-converter.html 4videosoft DVD to iPhone Converter Step 0: Run 4Videosoft http://www.4videosoft.com/download/dvd-to-iphone-converter.exe DVD to iPhone Converter. http://www.4videosoft.com/guide/iphone-mate/dvd-to-iphone-converter.gif Step 1: Import DVD. Place the DVD into your DVD drive and click the “Load DVD” button to load DVD. Step 2: Video settings. Select the output video format you want from the “Profile” drop-down list. Step 3: Place video Click “Open Folder” button to open your output destination file. Step 4: Start conversion Click the “Start” button to start your conversion and in a short while it will be finished. Second: How to convert video for iphone with http://www.4videosoft.com/iphone-video-converter.html 4videosoft iPhone Video Converter Step 0: Download and install 4Videosoft http://www.4videosoft.com/download/iphone-video-converter.exe iPhone Video Converter http://www.4videosoft.com/guide/iphone-mate/iphone-video-converter.gif When you finished the download process, run the .exe file to install it. Step 1: Click “Add files” button to import videos. Step 2: Extend the "Profile" category to select an output format. Step 3: Click “Open Folder” button to open your output destination file. Step 4: Click the “Start” to convert. Third: How to transfer files between two iPhone , transfer iPhone files to Computer, import PC file or folder to iPhone and with http://www.4videosoft.com/iphone-transfer.html iPhone Transfer 3.1. How to transfer songs and videos and other data between two different iPods. Step 1: Download and install 4Videosoft http://www.4videosoft.com/download/iphone-transfer.exe iPhone Transfer Step 2: Connect iphone Connect your two iphone to your computer via USB cable. Step 3: Find your data. Open the library/playlist that you want to export files. Pick the files that you need to transfer. Step 4: Transfer data Just click “ipod to ipod” button and it will show you the folder of another iphone that you want to transfer to. Click OK. The transfer can be finished automatically. 3.2. How to backup iphone data on your computer. Step 1: Connect your iphone. Run the software, and connect your iphone to your computer via USB cable. After done, the iphone icon and its library and playlists will appear in the Device list. Step 2: Find your files Open the library/playlist that you want to export files, and then check the file(s) you want to export in the file list. Step 3: Backup files Click “ipod to computer” button to select the destination of the exporting files and start exporting files. 3.3. How to transfer songs and videos from computer to iphone without iTunes. Step 1: Connect iphone. Connect your iphone to your computer via USB cable. Step 2: Find data Click “computer to ipod” button to seek the files or folders that you want to import to iPod and click OK. The process of importing will be finished instantly. Fourth: How make ringtone for iphone? Step 0 : Download 4Videosoft http://www.4videosoft.com/download/iphone-ringtone-maker.exe iPhone Ringtone Maker http://www.4videosoft.com/images/guide/iphone-ringtone-maker/steps.gif Step 1: Click “Browse…”( Button 1) to import the file(audio or video file) that you want to make ringtone from it. Step 2: Click Episode button to listen the music to find what you want as ringtone. Area 1: Drag the start & end slider to set your wanted episode Area 2: Type the start & end time in the corresponding text box directly to get the exact episode. Step 3:Click Whole Button to pre-listen the converted audio before generate. Step 4: Click “Browse…” ( Button 2) to choose the output destination. Tip 1: Check "Export to iPhone" option, the converted ringtone will be loaded to your iPhone directly. Step 5:After all the settings are finished, click “Generate”( Button 3) to begin making your own iPhone ringtone. Tips: How to make wonderful DVD/video editing (Merging, Trimming, Cropping, Effect adjusting, Capture picture) 1. How to change your video effect If you want to adjust the effect of your movie, please click the “Effect” button and a pop-up effect window will appear. It allows you to edit your movie’s effect including “Brightness, Contrast, Saturation and Volume”. http://www.4videosoft.com/guide/video-edit/effect.gif 2: How to crop off the black edges and adjust the size of video play region By using the "Crop" function you can crop off the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices http://www.4videosoft.com/guide/video-edit/crop.gif 3: How to split your video The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the exact time-length of the clip or you can directly drag the slide bar to the position you want. http://www.4videosoft.com/guide/video-edit/trim.gif 4: How to join the videos If you would like to put several files into one output file, please tick the check box of the “Merge into one file”. 5: How to save your favorite picture If you like the current image when preview video, you can use the "Snapshot" option. Just click the "Snapshot" button, the image will be saved and you can click the "Open" button next to "Snapshot" button to open your picture. |
