Home > Message Board > Home Audio > Speakers > Amp for Dynaudio Focus 110, recommend...
Author Thread: Amp for Dynaudio Focus 110, recommendations please?
Username: Massiven
Hi,
I have a problem with finding an amp for my Focus 110 and I wonder someone can give me some advice? My listening room is (joined kitchen and living room/listening room) which measures 3.8m x 9m, although I listen in area 3.8m x 4.5m, which is half of the room. Focus is on the longer wall.
Do you think I would be able to run my focus 110 successfully with integrated or power/pre combination? Are there any other recommendations in £500-£1000 range?
How about tubes for Focus 110?
Any ideas will be appreciated.
Cheers
Username: Massiven
And yes, I listen mostly to classical and jazz, vocal music too. I like lively, fast sound, not boomy bass, but warm sound with sweet highs. (if that is all possible in Hi-Fi)
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Speakers > Amp for Dynaudio Focus 110, recommend... [ « Previous ] [ Next » ]
