Thread: NEED HELP PLEASE |
New member Username: Gregsp09
Seattle,
WA
Post Number: 1 Registered: Oct-09
| Posted on Thursday, October 08, 2009 - 11:00 pm: |
I am having a big problem with my reciever. It is pretty new and a fairly nice reciever too, but for some reason whenever I turn up the volume any higher than about 15% of the max volume it just shuts off. Any ideas on how to fix it or what it wrong? |
Seattle,
WA
Post Number: 2 Registered: Oct-09
| Posted on Thursday, October 08, 2009 - 11:06 pm: |
This is also the second reciever I have had this happen to with my current speakers. Could they be too loud of speakers for the two amps? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 14056 Registered: May-04
| Posted on Friday, October 09, 2009 - 11:29 am: |
. "Could they be too loud of speakers for the two amps?" Not a chance. If this is a pretty new receiver, I'd be talking to the shop where you made the purchase. Off hand I'd say you were doing something wrong, it's highly unusual for two receivers to have the same problem out of the box. Call the retailer and let them sort this out by asking the appropriate questions. Oh, you do have good clean connections at all points on the receiver and speakers, right? No stray wires touching anywhere? . |
Platinum Member Username: Nuck
Post Number: 13678 Registered: Dec-04
| Posted on Friday, October 09, 2009 - 02:08 pm: |
GH, would you like to identify the receiver and speakers by model? |
Post Number: 13679 Registered: Dec-04
| Posted on Friday, October 09, 2009 - 02:10 pm: |
15% volume is like one watt. When you identify the receiver, describe any indications when it shuts down, which(if any) led's? Messages? |
Silver Member Username: Magfan
Post Number: 544 Registered: Oct-07
| Posted on Friday, October 09, 2009 - 07:43 pm: |
Add 'Odd smells' and 'bad distortion' to Nuck's list. Does it run long enough to get hot? Lights in the house dim? If possible, bring your speakers to the point of receiver purchase and let them blow up some of there stuff, or show you what you are doing wrong. One 'bad' would be to hook both speakers up to one channel.....the result for most current receivers will be similar to what you describe. |
