Home > Message Board > Home Audio > Subwoofers > Stereo pre out to mono sub
Author Thread: Stereo pre out to mono sub
Username: Pdaghe2
my stereo amp has R and L pre outs (no dedicated sub out). My active sub has a single line level in ( in addition to speaker level inputs which i don't want to use). Should I connect either the R or L pre out on amp to line level in on sub (and in this case am i losing info from other channel) or combine both the R and L pre out with a RCA y-splitter to feed both of them to the single line in on sub.
thanks in advance.
Username: Dmitchell
Ottawa, Ontario
Post Number: 3107
The sub is mono. Just run one RCA cable out to the sub. Doesn't matter which one (R/L). If you're obsessive like me, you can run the Y splitter out of the L/R, then one line to the sub.
Username: Magfan
Post Number: 525
Just hooked up a TV for brother-in-law.
While there are L/R RCA's, the L is additionally marked (mono) if not using a stereo source.
My sub is also marked this way, though I use stereo pre-outs to L/R inputs.
Username: Nuck
Post Number: 13651
do not mate the outputs, as the single channel output is not expecting to see an active input voltage, and the thing may have a fit.
Username: Pdaghe2
Thank you Nuck,Leo and David for the comments.
I guess i will just connect the L pre out to the mono input on sub. My question is still: do we lose low frequency info from the R amp pre out? is it worth getting a stereo sub?
Username: Jan_b_vigne
Dallas, TX
Post Number: 14041
What's the system?
There are advantages to having two subs but there isn't a "stereo sub" (in most cases and at most reasonable pricing), just an active (powered) subwoofer with L/R inputs where the inputs of the subwoofer plate amplifier do the summing of the two channels in the circuitry of the plate amp. This is far preferable to using a "Y" connector for the reasons Nuck suggested.
You can split an output but you should never combine an input. Let the circuitry do that job.
Bass is generically mixed into mono by all record producers to provide a simpler task for the amplifier(s) and the recording studio mastering labs. It's unlikely you will loose any bass with a single connection unless you listen to some very, very off beat recordings and even that would be a minimal loss.
As Leo suggests determine which output from your receiver is the Mono mix output. The information should either be on the reciever or in your owner's manual. This guarantees no loss of bass information even if you are listening to Albanian Phart Music (APM). If it doesn't mark one output as mono, then don't worry.
You'll have some advantages to running two separate subs in one room if you can space them on separate walls and do a proper set up. Just plunking a sub where it fits won't gain you anything with one, two or a dozen subs. Put "subwoofer placement" into a search engine and do some reading before you go a plunkin'.
If the system is a low to mid fi system, then you would do much better for yourself than spending money on another sub at this point. So, rack/bookshelf/entry level receiver systems, don't bother. Separate components and high dollar everything with high dollar set up, consider it down the road.
Otherwise, find that mono output from your receiver.
If the receiver looses it's main amplifier input and produces no sound when you plug into the "pre out", then you can use a "Y" splitter to run one side of the "pre out" to the subwoofer and one side back to the "main in" on your reciever. If there are straps or a "U" style connector between your reciever's "pre out" to a "main in", replace those with some better quality interconnect cables and you'll likely hear a bit better sound overall.
Username: Pdaghe2
Thank you Jan. Your comments are always very enlightening. My amp is a denon PMA 2000 ivr. It has R and L pre outs without any designation for which is a mono. For some reason people always suggest the L to use for mono. I will do that. I just purchased a martinLogan Vantage (goes down supposedly to 35 Htz. I am not sure what the sub will add ( i listen exclusively to classical music, orchestral, chamber and solo), Just thought to try if the sub would integrate well with the system.
Username: Nuck
Post Number: 13701
That sub should play well for your interests, pd.
Placing it in a corner will bloat the bass, that one should be placed carefully.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Subwoofers > Stereo pre out to mono sub [ « Previous ] [ Next » ]
