Thread: 7.1 Channels can they power multi-room speakers? |
New member Username: Breadbrian
Culver City ,
CA
United States
Post Number: 1 Registered: Sep-09
| Posted on Friday, September 25, 2009 - 03:51 pm: |
Dear ecoustic gurus: Recently my wife and I moved into a new home with pre installed ceiling speakers. Each room has a fader that controls the volume and the wires converge in the living room. I counted 6 pairs of wires. I was speaking to an audio friend of mine and he said we could potentially purchase a 7.1 channel and use each of the channels to power the separate speakers. Our needs are simple in that we want the same music in all the rooms. Do you recommend a multi channel amp? but from what i can see this far exceeds our budget. With our first baby due in February, I am looking for the cheapest way to make this possible. (need to start saving for a college fund ) Thank you everyone for your time and much needed advice! |
Platinum Member Username: Nuck
Post Number: 13566 Registered: Dec-04
| Posted on Friday, September 25, 2009 - 05:19 pm: |
Grab the most economical solution possibble and take care of the little ones. |
Post Number: 13567 Registered: Dec-04
| Posted on Friday, September 25, 2009 - 05:24 pm: |
Ignore the built in speakers for now, buy a receiver and a pair of speakers for now from a pawn shop. You are very soon going to be listening to a baby monitor 24/7 anyhow. so buy from a pawn shop. Spend 50$ Trust me, when you have time for just you 2 together, you will be sleeping. Congrats and good luck. |
Culver City ,
CA
United States
Post Number: 2 Registered: Sep-09
| Posted on Friday, September 25, 2009 - 06:31 pm: |
wise words... true true thanks! |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 3088 Registered: Feb-07
| Posted on Tuesday, September 29, 2009 - 05:45 pm: |
Yes, you could use the receiver to power all the speakers. My old Pioneer receiver did "5.1 Stereo", which actually sounded surprisingly good. A newer receiver that does 7.1 would presumably be able to the same. But Nuck is right. You're gonna be too tired to enjoy multi-room music for awhile. Been there, done that :-) Twice. |
