Thread: RCA Interconnects with Ground |
New member Username: Brocjas
Albany,
NY
Post Number: 3 Registered: Aug-06
| Posted on Monday, September 21, 2009 - 09:08 pm: |
Have a Music Hall 5.1 with the RCA's and bundled ground that came with it. I was wondering what others have done to "upgrade" these at a reasonable cost ? Also if you go with a better set of stand alone RCA's without the bundled ground wire, what type & size wire can be used to establish the ground connection. Thank You for your feedback on this. |
Platinum Member Username: Nuck
Post Number: 13532 Registered: Dec-04
| Posted on Wednesday, September 23, 2009 - 04:52 pm: |
Hi Brian. Yes you can replace the cables with any flavour that you like, and the ground can be various condustors as well. The ground is restricted by connector size only, but need not be more than 22g twisted or brained copper, really. The cables can be shielded or non, ferrite rings can be wound with them as well. What is your cart, original? What phono do you run it to? |
Albany,
NY
Post Number: 4 Registered: Aug-06
| Posted on Wednesday, September 23, 2009 - 06:59 pm: |
Hi Nuck - Thank You for the response, you confirmed my thought that you could run about anything, $, $$, $$$, as the RCA's, the ground was the unknown as to size and character. The 22g braided copper info answers that question. With the Music Hall 5.1, I am still using the supplied cart, Goldring 1012GX. In looking for that "just right " sound a cart change out would probably yield more than changing the RCA's. I just made the move to a tubed preamp, with a McIntosh C2200. While the reviews go both ways regarding this phono stage, it is a noticeable improvement over the previous, which was a Rogue Audio Stealth into a line stage of the Arcam FMJ A32. When times permits I will run the Stealth into a C2200 line stage just to see ??? Did you have any thoughts regarding "reasonable" RCA options ? |
Post Number: 13533 Registered: Dec-04
| Posted on Wednesday, September 23, 2009 - 07:34 pm: |
i would just order cables from Blue Jeans cables. Simple and easy, and a good reliable baseline. Cheers! |
