Home > Message Board > Home Audio > Speakers > Interference problems
Author Thread: Interference problems
Username: Danoe888
My setup: PS3 and Computer connected to Samsung t240 Touch of Color HDTV, PS3 via HDMI, computer via DVI. I have my Bose speakers currently plugged into my computer, but I also want to play my TV though the speakers as well. When I use the headphone jack on the side of the TV and put it into the input port on the Bose control pod I get a ringing noise, I've tried 3 separate cables, same result. What would be the cause of this and how would I resolve the issue? Thanks
Username: Nuck
Post Number: 13486
Wrap the cable through a ferrite ring, or purchase a wrap-around RF noise suppressor.
Username: Danoe888
Appreciate it, the ferrite ring, does it just snap on, and where would I need to put it? Near the TV or the bose input jack?
Username: Nuck
Post Number: 13500
If you get one, then get several, I think. They go closest to the load.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Speakers > Interference problems [ « Previous ] [ Next » ]
