Thread: Jensen 720 Watt Amp |
| Posted on Sunday, October 12, 2003 - 11:30 pm: |
I have a jensen 720 watt amp. I hooked it up to my car with a 4 gauge wire. The fuses blew on the amp. Then I disconted the wire from the battery and replaced all the fuses then reconcted it again adn they blew again. I dont know what to do. Should i take it apart and look in side? The protect light also always stays on. Im lost Please help. |
Ivan |
| Posted on Friday, November 21, 2003 - 09:23 pm: |
throw it away I had the same problem dude, get a rockford 501S Amp that'll due it. The jensen is a low power amp that blows quick if the power is to much |
Lauren |
| Posted on Sunday, November 30, 2003 - 09:38 pm: |
heh heh...all i can say is that sucks a hiry tit. |
Lauren |
| Posted on Sunday, November 30, 2003 - 09:39 pm: |
i spelled hairy tit wrong...hah hah hah |
New member Username: Stez_head
Post Number: 17 Registered: 01-2004
| Posted on Saturday, January 17, 2004 - 07:11 pm: |
It sounds like an internal circitry board probalem i wouldnt take it apart because the circitry boards are very complex and is. Easy to break components geting them out take the amp to the nerest auto electrition and see if you can have it repaired before you throw anything away. Oh check the internal fuses. |
