Thread: My first setup... i need upgrades |
Silver Member Username: Longbluesquid
Post Number: 191 Registered: May-06
| Posted on Sunday, September 20, 2009 - 12:29 pm: |
I have a Cambridge Audio 640A v2 Oppo DV-980H Im playing with ELT525M from AV123 there on Sanus speaker stands I have Ultralink speaker cables and Nordost interconnect from Amp to cd... Im thinking about what i need to upgrade.. i want to do new speakers (towers or bookshelves) but i was thinking a dedicated cd player or DacMagic... i also play movies on this but music is the main focus.. I have connected my PS3 and Xbox on it... |
Platinum Member Username: Nuck
Post Number: 13465 Registered: Dec-04
| Posted on Sunday, September 20, 2009 - 12:32 pm: |
Abe, what qualities do you want to enhance/what deficiencies do you want to address? |
Post Number: 192 Registered: May-06
| Posted on Sunday, September 20, 2009 - 12:43 pm: |
Well i want to get the full potential out of my Amp so ill need speakers, I cannot give up my Oppo because of SACD ( the only player id be able afford that can do it all ) but i feel i wont be able the full potential of my oppo... i lisyen to alot of music jazz, rock, pop, rap/Hip-hop, world my music interests are very wide.... |
Post Number: 13468 Registered: Dec-04
| Posted on Sunday, September 20, 2009 - 01:01 pm: |
Have you heard any of your componants used to their 'full potential', in any setting, in your opinion? |
Post Number: 193 Registered: May-06
| Posted on Sunday, September 20, 2009 - 01:18 pm: |
Nope.. tell you truth all my components have been bought blindly or based on reviews... only auditioning i did was in PA when i was looking for an Integrated i audioned the Nad C326BEE with B&W bookshelves ( XT model ) and Nad 565BEE cd player but i bought the CA 640A cause it was on clerance on audio advior... |
Post Number: 13470 Registered: Dec-04
| Posted on Sunday, September 20, 2009 - 02:04 pm: |
My next suggestion is not a fun one, but can be cheap. Look at your room layout, placement and acoustics. The room is over 50% of the result. Stop buying, start listening and do some reading on room acoustics. |
