Home > Message Board > Home Audio > Phono > MY SL-23 WON'T turn off !!!
Author Thread: MY SL-23 WON'T turn off !!!
Username: Lethomas
Calif.
Conus
I have a Technics SL-23, I received after my Dads passing. It probably sat many a year. When I got it, it first would not spin .... belt was in pieces, cleaned & replaced....OK. Then the speeds were intermittent ..... cleaned & lubed the pots....better. NOW the unit won't shut off, the micro switch is good... it appears the linkage is not going far enough back to engage switch, BUT the tonearm goes back to its stand and sits down just fine....but still won't shut off. Does anybody have a timing guide or mechanical pix of under the platter and under the table ...the main gear and linkages appear to be OK, perhaps something is in the wrong place or missing ???? I blame "time" and sitting, BUT it could have been a problem when my Dad was alive and he just stopped using it. ANY help or direction on this would be a great help. Thanx
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Phono > MY SL-23 WON'T turn off !!! [ « Previous ] [ Next » ]
