Thread: Why 8 ohms speaker are used in Mobile phones |
New member Username: Piyush_gaur
Post Number: 2 Registered: Sep-09
| Posted on Thursday, September 03, 2009 - 02:41 am: |
hi just want to know why 8 ohms speakers are use din Mobiles phones and not 4 ohms or 16 ohms speaker. i understand 4 ohms will draw more current and hence are not used. in that case why 16 ohms are not used as they will draw less current than 8 ohms. regards Piyush |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13886 Registered: May-04
| Posted on Thursday, September 03, 2009 - 10:01 am: |
. There will be less power produced into a 16 Ohm load. |
Platinum Member Username: Nuck
Post Number: 13342 Registered: Dec-04
| Posted on Thursday, September 03, 2009 - 09:42 pm: |
See, the phones are getting so small, that 16 won't fit. It is 8 for now, but they are on rations. Whiz kids are working on just one really small one even as we speak. Her name is Milli. |
Post Number: 3 Registered: Sep-09
| Posted on Friday, September 04, 2009 - 03:55 am: |
hi Jane / Nuck thanks for the information then just wondering why dont we use the 4 ohms one. is it just because it will take more current !! and for heat transfer as more current will go in. are these correct reasons ? thank you very much REgards PIyush |
Silver Member Username: James_the_god
Lancaster,
Lancashire
England
Post Number: 812 Registered: Jan-05
| Posted on Friday, September 04, 2009 - 07:57 am: |
Nice to meet you Jane! |
Dallas,
TX
Post Number: 13887 Registered: May-04
| Posted on Friday, September 04, 2009 - 09:01 am: |
. There is limited current storage in the battery. Use less currrent and the battery lasts longer. I doubt heat has anything to do with a mobile phone's speaker choice since ic's don't produce much heat. . |
Post Number: 13345 Registered: Dec-04
| Posted on Friday, September 04, 2009 - 09:30 am: |
Plus the need for speakerphone and the volume required for that function. |
Post Number: 4 Registered: Sep-09
| Posted on Tuesday, September 08, 2009 - 08:23 am: |
ok Guys !! i understand now - thank you very much  |
