Thread: Need NAD T763 firmware upgrade |
New member Username: Glennh70
Australia
Post Number: 1 Registered: Sep-09
| Posted on Tuesday, September 01, 2009 - 07:08 pm: |
Hi I have an NAD T763 with firmware 1.24. I would like to update the firmware to the latest version. Can someone tell me where to go to get it, as NAD no longer will send it to you. Thankyou |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 2992 Registered: Feb-07
| Posted on Sunday, September 06, 2009 - 02:47 pm: |
Have you contacted your dealer? Maybe they can install if for you? |
Australia
Post Number: 2 Registered: Sep-09
| Posted on Monday, September 07, 2009 - 05:05 am: |
Yes i have, and they can install it. I thought i might save some money and do it myself. The next time i go to the city, i may take my NAD with me and get the firmware update |
Platinum Member Username: Nuck
Post Number: 13365 Registered: Dec-04
| Posted on Monday, September 07, 2009 - 08:12 am: |
How much are they charging for the procedure? |
Australia
Post Number: 3 Registered: Sep-09
| Posted on Monday, September 07, 2009 - 04:56 pm: |
$100, i think. It could be a bit more by the time it is done |
Post Number: 13383 Registered: Dec-04
| Posted on Monday, September 07, 2009 - 05:28 pm: |
Bast@rds! |
Ottawa,
Ontario
Post Number: 3000 Registered: Feb-07
| Posted on Monday, September 07, 2009 - 06:29 pm: |
It should be a free service. Much like Windows is perpetually broken, MS provides updates..... |
Post Number: 13386 Registered: Dec-04
| Posted on Monday, September 07, 2009 - 06:50 pm: |
Dave, you crack me up! |
Ottawa,
Ontario
Post Number: 3005 Registered: Feb-07
| Posted on Monday, September 07, 2009 - 06:52 pm: |
Hopefully in a good way? |
Post Number: 13388 Registered: Dec-04
| Posted on Monday, September 07, 2009 - 07:17 pm: |
If the update/download comes through windows, It is worth the c-note for somebody else to guarantee that it works, LOL! |
Ottawa,
Ontario
Post Number: 3009 Registered: Feb-07
| Posted on Monday, September 07, 2009 - 07:26 pm: |
Good point. At least you can just reinstall Windows if/when things go awry. |
Post Number: 13391 Registered: Dec-04
| Posted on Monday, September 07, 2009 - 08:21 pm: |
Yeah, just another Saturday night reloading my OS. |
