Thread: ISO Receiver for Acoustic Energy Aegis Evo 3 Speakers |
New member Username: Dcholly
Post Number: 1 Registered: Aug-09
| Posted on Wednesday, August 26, 2009 - 04:37 pm: |
I bought my AE Evo speakers about 6 years ago. I bought my Yamaha receiver about 20 + years ago and need to replace it. Any suggestions on what receiver I should buy. Do I also need a sub-woofer? I will use the speakers to listen to CDs, DVDs, radio, & TV. Thanks. |
Platinum Member Username: Nuck
Post Number: 13288 Registered: Dec-04
| Posted on Wednesday, August 26, 2009 - 04:48 pm: |
Hi Holly. Whether or not you need a subwoofer is up to you. Varying signals from tv, cable and radio are different. Remember that the minimum signal from fm is 40 Hz, which is plenty low on bass, but not a blow up movie. If you are looking at 2 channel receivers, there is Outlaw, NAD, Rotel and a few more to look at, and most(?) have sub out for lfe for movies, or at least a pre-out for another connection. Pick your flavour and price. |
Post Number: 2 Registered: Aug-09
| Posted on Wednesday, August 26, 2009 - 07:28 pm: |
Hi Nuck, Thanks for your response. I know nothing about Hz or even what a sub-woofer does so I really need some basics. I just want to make sure the receiver isn't too powerful for the speakers or vice versa. I'm in the States and think you may be listing some UK products as I haven't heard of them. I would like to buy something used via Craigslist (http://washingtondc.craigslist.org/ele/) - lots of offerings - Yamaha, Onyko, Pioneer, etc. -- but most are for home theatre set-ups and I only have 2 speakers. |
Post Number: 13289 Registered: Dec-04
| Posted on Wednesday, August 26, 2009 - 09:20 pm: |
Holly, no products are too powerful for any others to match, it is just how you implement them. The worst thing to do is power your speakers with a cheap receiver, thats how speakers are damaged at parties, etc. The models that I named are widely available, as is Harmon Kardon, which is a good brand, IMO. People are selling these things used for a reason, usually because they aren't so very good for music, as compared to 5 channels for movies. A subwoofer delivers the lowest bass frenquencies, the ones that tickle your tummy. |
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 903 Registered: Dec-03
| Posted on Thursday, August 27, 2009 - 11:21 am: |
Is the yamaha receiver broken ? If not, I would keep it - if it's CR-series. They sound good - better than today's yamahas. To the good recomendations already made, I would add onkyo integra, Luxman R-115 or R-117, and acurus. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 3791 Registered: Sep-04
| Posted on Thursday, August 27, 2009 - 01:35 pm: |
Sounds to me you want a 2-channel receiver (i.e. a tuner/amp). Anything with around 50 - 60 watts per channel will be powerful enough to drive the speakers you have. However, they all sound different (because different people make them) so your mileage may vary with different brands. You could try NAD's newish C725BEE (http://nadelectronics.com/products/hifi-receivers/C-725BEE-Stereo-Receiver). I've had good results with NAD/AE pairings in the past. |
