Home > Message Board > Home Audio > Amps > Amp stand
Author Thread: Amp stand
Username: Nuck
Post Number: 13235
As I ponder a new rack, I will put this out there.
My Gallo SA sub amp has a fan that moves air front to back, and does not get warm at all.
I am contemplating using this amp as a base for the Mac 6900, perhaps even with a slab in between.
There is also a possibility of using 2 sub amps in the future, but in the stack, not on the floor.
Does anyone see a problem with this, other than the base unit(s) holding up the 85lb Mac?
TIA
Username: Stu_pitt
Irvington, New York
Post Number: 3439
I think you should keep some distance between them. Noise from one may effect the other. Also consider vibration. Just my gut feeling.
Stacking the sub amps on each other would probably work out fine. Just another gut feeling.
Username: Nuck
Post Number: 13258
Thanks, Stu.
I was considering the amps on the floor thing for a while, but the rack will be better, and I will use shelves at the cost of height.
Username: Jazzman71
Phoenix, AZ
Post Number: 895
Vibration would be my concern as well. I agree with Stu.
Username: Hawkbilly
Nova Scotia
Post Number: 653
What sort of rack are you considering Nuck ?
Username: Nuck
Post Number: 13264
Probably going to have a friend of mine carpenter one up for me.
Not sure of construction yet...
And an Oak sandbox for the VPI.
Username: Hawkbilly
Nova Scotia
Post Number: 654
I've been thinking about doing the same thing. Let me know what sort of design you decide on.
Username: Nuck
Post Number: 13267
Likey a vanilla vertical support stand of no great description.
Or something wild, hehe.
Username: Mike3
Wylie, Tx
Post Number: 2118
If you have the floor space, which I know you do, why not just build Oak sandboxes for everything?
It can be done tastefully so keep the man-cave thoughts to yourselves.
Nuck has a basement if I recall so isolation would be more important in his case such as mine with the 2nd floor listening room.
Username: Nuck
Post Number: 13277
I have reduced the componant count to the point that a small stand will suffice, plus the sandbox.
I dont think I like the idea of multiple sandboxes for my room, somehow, it is still small.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2928
If you don't want to go the DYI, pick up one of these from Future Shop (I know, I know....)
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000F S10095963&catid=
I have my Mac system on it and it's surprisingly good quality. For 189 bucks you can't go wrong.
Username: Soundgame
Toronto, Ontario
Post Number: 920
I like the look of some of the Sanus stuff. Your rack looks pretty solid Dave and my read of the specs sounds like it's sturdy enough for some heavyweight gear.
Doesn't say how much room there is between the shelves.
Username: Dmitchell
Ottawa, Ontario
Post Number: 2947
I can't remember the actual clearance George. It's a lot of space, though. More than enough for some big-@assed Mac gear, with breathing space. They're rated for 100 lbs per shelf. I just bought another one today, as a matter of fact. Renovating the living room and decided to step up from the Canadian Tire shite I had sort of haphazardly balancing everything.
Username: Nuck
Post Number: 13299
The open shelf look may have to work for me, as the 6900 is side vented.
The fullsides that I have used so far have granted prettty solid mid vocals, however.
The stand plays a fairly predominant role in how the room sounds, with high flat sides.
Username: Mike3
Wylie, Tx
Post Number: 2124
I guess Nuck must have a cat or cats he has not told us about.
Username: Nuck
Post Number: 13302
No pets, no plants, no worries
Username: My_rantz
Australia
Post Number: 2450
. . . ain't got no cigarettes . . .
Username: Nuck
Post Number: 13353
Well, sales so far are going at MSRP for Gallo amps. I wonder if i should not sell mine and go with plate amps, in funky enclosures.
Plate amps are active(with phase control) yes?
The woofer coils in question are pretty stable passive 4 ohm loads.
Username: Exerciseguy
Brooklyn, NY
United States
Post Number: 2826
You know I love the Mapleshade racks.
http://www.mapleshaderecords.com/audioproducts/samson_hub.php
Username: Nuck
Post Number: 13361
Sweeeeeet
Username: Dmitchell
Ottawa, Ontario
Post Number: 2995
You gonna order one Nuck?
Username: Nuck
Post Number: 13367
A 3 tier model is 1800USD
probably not
Username: Soundgame
Toronto, Ontario
Post Number: 945
How about getting you carpenter friend to build it Nuck - perhaps materials and a bottle of J.D.?
Sound like a plan?
Brooklyn, NY
United States
Post Number: 2827
That's kind of what I was getting at; I'm sure the Mapleshade stands are superb & will last a lifetime.
You know, my TV table (www.boltz.com) cost me $1K, and it isn't nearly as handsome or functional as the Mapleshade stands.
I say go for it!
Username: Hawkbilly
Nova Scotia
Post Number: 665
If you could get the hardwood in that size, the rest is fairly straightforward, although the individual parts would still cost a pretty penny,
Username: Nuck
Post Number: 13370
The hardware will probly have to come from Mapleshade, particularly the nice points.
Maybe.
My friend would love to get his hands on some thick solid maple, but we have to source the stock.
Brooklyn, NY
United States
Post Number: 2829
Keep an eye out @ Audiogon & CAM.
http://cgi.audiogon.com/cgi-bin/srch_fs.pl?searchstring=mapleshade
http://www.canuckaudiomart.com/search.php?submit=1&keywords=mapleshade
Username: Nuck
Post Number: 13374
Thanks CM.
I am also as likely to buy stock and machine feet myself, given a few hours.
Username: Magfan
Post Number: 502
I've been puzzling thru racks myself
This may help....or not!
http://www.stereophile.com/reference/52/index.html
Fort Hamilton, NY
United States
Post Number: 2868
Edensound, the poor man's Mapleshade.
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1256242158
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Amps > Amp stand [ « Previous ] [ Next » ]
