Home > Message Board > Home Audio > Amps > Amp questions
Author Thread: Amp questions
Username: Detroitjuggalo
I'm setting up a new system in my truck. so far I have 4g power and ground wire and my speaker wires have been ran. My speakers I have are a pair of Lanzar Max 12's (new from friend) 4 ohms 1000watts max. And I'm now looking for my amp.
My friends have 2 amps for sale, a Pyramid PB449X and a Kenwood KAC-8104D. I'm not sure about how the power ratings work and I know kenwoods are better. but the pyramid is in my price range. If i could get more, would the kenwood be alot louder than the pyrmaid?
Here is what I found on the details
Kenwood KAC-8104D Class D Mono Power Amplifier
Maximum Power Output: 1000W
RMS Power Output (14.4V ):
300W x 1 at 4ohms (20-200Hz 0.5%THD)
500W x 1 at 2ohms (100Hz 0.8% THD)
Built-in Variable Low-pass Filter: 50-200Hz (24dB/oct)
Built-in Infrasonic Filter: 15/25Hz (18dB/oct)
Bass Boost (0-18 dB at 40 Hz )
Class D Amplifier Circuit
Aluminum Die Cast Heat Sink
Power MOS-FET Switching Power Supply
Speaker Level Input
Signal Sensing Turn-On
2 Ohm Load Capability
Line Output Terminals (RCA) for Extension
Blue Illumination
Gold Plated Power and Speaker Terminal
Dimensions (W x H x D): 11-1/16" x 2-3/8" x 9-7/8" (280mm x 59mm x 238mm)
Pyramid
PB449X 1000 Watt 2 Channel MOSFET Amplifier
Two Channel Bridgeable Amplification
2x500 Watts/1x1000 Watts Output Bridged @ 4 Ohms
Variable Gain Control/Remote Turn On/Off
MOSEFT Pulse Modulation Power Supply
2 Ohm Stereo Stable
Built-in Bass and Treble Control
Gold Plated RCA Low Level Inputs
Hi-Level Low Impedance MOLEX Input
Speaker Output Terminal Strip
S/N Ratio: Greater Than 90dB
THD Less Than 0.04%
Frequency Response: 15-30k Hz
Overload/Thermal/Short Circuit Protection
Power On LED Indicator
LED Diagnostic Condition Indicator
Automotive Type Fuse Protection
Dimensions: 15.25''W x 2.25''H x 10.67''D
Username: Artk
Albany, Oregon
Post Number: 10532
Car audio is elsewhere on the forum, please post your question there.
sorry long day, reposted in right forum
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Amps > Amp questions [ « Previous ] [ Next » ]
