Home > Message Board > Home Audio > Phono > Need help
Author Thread: Need help
Username: Jessul
I have two 2-way kenwood speakers(max input 100w per speaker) and a Technics SL-B350 tunrtable. I want to use the speakers with the tunrtable. What type of receiver/amp should I get????
Username: Mike3
Wylie, Tx
Post Number: 2093
Your best bet may be a pawn shop. Look for an older receiver, preferably one with a wooden casing. Make sure it has a phono input option for source.
Have them play it for you to make sure it works. Negotiate, try and stay at or under $40. If not, try another pawn shop.
Pioneer would be a good pick up.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Phono > Need help [ « Previous ] [ Next » ]
