Thread: Help with Tonearm/Cartridge Compatibility |
Silver Member Username: Jazzman71
Phoenix,
AZ
Post Number: 772 Registered: Dec-07
| Posted on Tuesday, July 14, 2009 - 09:32 pm: |
Awhile back, Jan posted a link to a tonearm and cartridge database where you could check resonance and compatibility of arms and carts. I am trying to check the compatibility of a VPI JMW 9 tonearm with a Clearaudio Beta S Aurum (wood) cartridge. My problem is I cannot find the compliance for the cart. It seems to be on the light side for the arm. What I do have: Arm effective mass: 7.7 g Cart weight: 6 g Tracking force: 2 g Arm shows range of 7-12 grams for cart. By contrast, the JMW 9 signature arm (9.9 g effective mass) has a range of 5-12 g for the cart. Seems like the stainless cart at 10 grams would be a better match for the lighter VPI arm? Thoughts? |
Gold Member Username: Mike3
Wylie,
Tx
Post Number: 2062 Registered: May-06
| Posted on Tuesday, July 14, 2009 - 11:43 pm: |
The first part of the post you seem to have answered your own question. The arm is more critical to your sound than the cartridge FWIW, so if all is relative to your budget I would upgrade there first. My thoughts? Why Clearaudio? |
Phoenix,
AZ
Post Number: 777 Registered: Dec-07
| Posted on Tuesday, July 14, 2009 - 11:50 pm: |
MW, http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1252162232&/VPI-Scoutmaster-with -JMW-9-ton Trying the gage whether the combo is worth a further look. Not sure it is very compatible, so wanted to check using tool JV had submitted before, but did not have all the specs to do so. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 13738 Registered: May-04
| Posted on Wednesday, July 15, 2009 - 09:45 am: |
. He's asking about the mechanical match between the arm and a specific cartridge, i.e. where the resonance of the system will fall. Here's the link to the database; http://www.cartridgedb.com/ I don't understand this sentence, "Seems like the stainless cart at 10 grams would be a better match for the lighter VPI arm?" A "stainless" cartridge? I know VPI has a stainless steel arm but I was not aware of anyone building a stainless steel body for their cartridge. You want to stay as close to the "ideal" center of arm/cartridge pairings as possible. Straying a bit to one side or the other will move the system resonance up or down depending on the direction the pairing falls. Higher resonance is normally the more destructive of the two since this pushes the resonance up towards warp/off-center frequencies and means the pair will have less success faithfully tracking discs that are in bad shape. It's a fair assumption that virtually all LP's have some degree of warp (watch your woofers when you play a disc, they probably bobble in and out no matter the quality of the disc) and most mass market discs will be slightly off center. You know how many and to what degree you have warped LP's in your collection. A record clamp or outer ring will minimize any warps and make the arm/cartridge match a bit less relevant. Matching the two pieces together results in less wasted energy (wattage/woofer motion) as the resonance is decreased in amplitude. The more the woofers stand still while tracking an LP the more energy is being used driving the system with the information in the grooves and not from the warp. You can search the database for exact numbers but I would guess the ClearAudio cartridges are all medium compliance designs. That and medium mass tend to be in the majority in today's market. . |
Dallas,
TX
Post Number: 13741 Registered: May-04
| Posted on Wednesday, July 15, 2009 - 11:30 am: |
. One important advantage of the Signature arm would be its damping system, which is not to my knowledge available on the lower priced version. The viscous damping system will work to stretch the acceptable range of cartidge matches. It also minimizes the uni-pivot bearing's wobble which can be somewhat disconcerting until you get used to its movement. The result is smoother, more consistent perfomance across the disc. . |
Phoenix,
AZ
Post Number: 781 Registered: Dec-07
| Posted on Thursday, July 16, 2009 - 10:29 pm: |
Jan, thanks for the info. The signature arm also has higher mass, which I think extends the lower range. They show 5-12 grams for the cartridge for the signature arm, and 7-12 grams for the straight JMW 9. The subject cart comes in wood (6 g) or SS (10 g). The pic in the audiogon ad shows it as wood. http://www.needledoctor.com/Clearaudio-Aurum-Beta-S?sc=2&category=367 |
Platinum Member Username: Nuck
Post Number: 12939 Registered: Dec-04
| Posted on Friday, July 17, 2009 - 08:28 am: |
I still did not get to weigh the mounting screws, which are part of one calculation. |
