Home > Message Board > Home Audio > Phono > Yamaha CR-600/Yamaha YP-D6 buzzing
Author Thread: Yamaha CR-600/Yamaha YP-D6 buzzing
Username: B3du553y
Bradenton, Fl
I try to use the turntable on Phono 1 and it buzzes.
I try it on Phono 2 and it doesn't play.
Is it the stereo or the turntable?
How would I go about fixing this?
Username: Jan_b_vigne
Dallas, TX
Post Number: 13739
You haven't provided much information. A "buzz" when using a phono input normally means the table has to be grounded to the receiver. There should ba a grounding wire running from the turntable that needs the be attached to a ground lug on the back of the receiver's input area.
Is there such a wire and lug on your system?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Phono > Yamaha CR-600/Yamaha YP-D6 buzzing [ « Previous ] [ Next » ]
